Old 07-12-2007, 04:24 AM   #1
Philhop's Avatar
Philhop is on a distinguished road
2x DVC not Working Subwoofers Plus Touchscreen PROBLEMS
Hi all been a while since I posted a problem but yes Its happened ,
We re did my sub box put it in the boot the box fell over and was facing upwards with the back on the amp.
We fully run the system out on a saturday night sounded great but all of a sudden it stopped!
We have checked
Amp (3000wrms at 1ohm) 12v in Light is going
Outputs to subs still outputting voltage
The subs are DVC 2 running at 1ohm
The cable looks fine done the battery test on both subs and nothing happens.... Any idea no way we would have blown both at the same time right?
Also on another note my touch screen has gone funny after a rebuild apparently it could be the ribbon on the GAIN unit but the ribbon looks fine , maby I should just RMA the board all it displays is white.
I would greatly appreciate any help in regards to the subs not fun after spending weeks building boxes with mirrors and perspecs will post pics soon!
my TURBO! Altezza!
ATEZZA / IS200 3SGE-TURBO 6SPD MANUAL , EPIA 13000, 512 RAM W/LAN , 100GIG , GPS , TOUCH, 3X LCD, FLUSH TOUCHPAD MOUSE, SOUNDBLASTER EXTERNAL
Philhop is offline   Reply With Quote
Old 07-12-2007, 08:40 AM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Double check your sub wiring. If you wired the DVC wrong, they will fight against each other magnetically/electrically and you won't get any output. If you leave it like that too long, you might have destroyed the subs.
The screen problem sounds like your ribbon cable is not plugged in all the way. Recheck that too. That was my problem in the past.
System always under construction
durwood is offline   Reply With Quote
Old 07-12-2007, 03:38 PM   #3
Philhop's Avatar
Now my soundblaster external has blown up all other usb devices get power but the sounblaster gets no lights Bummer
Thanks for your post durwood I dont think they were fighting against each other im sure they were wired correctly
my TURBO! Altezza!
Old 07-12-2007, 03:43 PM   #4
Philhop's Avatar
Regards the touchscreen the only thing that we changed was gluing it down with some glue that we think had some metal in it ...... that could have caused some problems! damn one of the chips gets really hot but we think its only on the touchscreen controller board
my TURBO! Altezza!
LCD Touchscreen was working ericw7748 LCD/Display 0 02-28-2007 01:42 AM
Weird touchscreen problems claylong LCD/Display 0 02-25-2003 08:46 AM
touchscreen not working Birrman54 LCD/Display 5 09-15-2002 12:09 PM
Yea! Got my touchscreen / lcd working Arby LCD/Display 19 03-06-2002 06:08 PM
ARBY!!! Did you ever have problems getting your HD working? dudah85 General MP3Car Discussion 9 06-13-2001 10:53 PM
