Old 07-13-2007, 07:21 PM   #1
johnsoccer316 is an unknown quantity at this point
fuse size on amp
hey its john again i was wanting to know what size fuse i should put on the wire that goes to the battier. because the amp i have doesn't have a fuse on it. its a rockford fosgate punch 201s 600 watts. if any one out there with info about this amp would you please let me know.
thank you
johnsoccer316 is offline   Reply With Quote
Old 07-13-2007, 08:00 PM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Here is what google told me when using the words rockford fosgate 201s fuse
Quote:
Rockford Fosgate Punch 201S incorporates proprietary technology, clean circuit design, and MOSFET output stages, all designed to bring out extraordinary detail in your music. With 50 watts of Rockford Fosgate power per channel, this amp will drive a pair of coaxial or component speakers with potency and strength you just can't get from an in-dash receiver - or a lesser amplifiers
Rockford Fosgate Punch 201S key features:
  • 200 watts RMS x 1 bridged output at 4 ohms
  • 100 watts RMS x 2 at 2 ohms
  • 50 watts RMS x 2 at 4 ohms
  • 4-ohm stable in bridged mode
  • Stereo or bridged mono output
  • Tri-way capable (Tri-Way Crossover required)
  • Requires 10-gauge power and ground leads - wiring and hardware not included with amplifier
  • 120 Hz high-pass, 80 Hz low-pass crossovers (12 dB/octave)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ - noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD - advanced protection circuitry for "intelligent" shutdown protection
  • Speaker- and preamp-level inputs\
  • Selectable Punch Bass (0/6/12 dB boost at 45 Hz)
  • 10-1/8"W x 2-7/16"H x 9-7/8"D
Rockford Punch 201S gives you built-in high- and low-pass crossovers that let you tailor your car music.
Manufacturer’s Box Included
  • Owner's Manual
  • 2-channel amplifier with 2 end caps (already attached)
  • RF illuminated power logo
  • Instructions
  • "Team RF" sticker
  • One 8.5" speaker-level input harness
  • In-line fuse holder with two connection/wire covers (accepts up to 8 gauge wire)
  • 20 Amp ATC fuse
  • One 7/64" Allen wrench
  • One 3/32" Allen wrench
  • One 1/8" Allen wrench
  • Four 7/8" self-tapping screws
  • 7/64" in-set screw
  • 1/8" in-set screws
  • Remote turn-on terminal connector
  • Amp Verification Certificate
System always under construction
durwood is offline   Reply With Quote
Old 07-13-2007, 08:25 PM   #3
ok thank you so much hope i could be of some help some day (just not on audio)haha
Size Of ANL Fuse? bird Car Audio 6 05-11-2006 03:15 AM
Amp running hot...?? Emerica2843 General Hardware Discussion 5 02-08-2006 06:40 PM
Amp running hot...?? Emerica2843 Car Audio 6 01-29-2006 08:29 PM
Wiring Distribution Fuse Box, cable length etc Pabs General Hardware Discussion 0 09-06-2004 05:59 PM
Wiring from battery and switch questions bombboyer Power Supplies 50 02-06-2004 07:17 AM
