Old 07-17-2007, 10:47 AM   #1
mrhonnesty99 is an unknown quantity at this point
Jl 500/1 Gone Bad
To make a long Story short i got to eat it or fix it.
I have Added a picture. What are the odds of this thing working once i replace the damage, assuming that i can find the parts?
ps: the amp powers on without a problem just the outputs are fried.
mrhonnesty99 is offline   Reply With Quote
Old 07-17-2007, 10:50 AM   #2
binary.h4x's Avatar
binary.h4x
I would go ahead and replace those resistors too, while you are at it, they are cheap.
binary.h4x is offline   Reply With Quote
Old 07-17-2007, 11:09 AM   #3
I think they are resistors is that what they are called it has a white # 470. is there any special place i might find these?
Old 07-17-2007, 11:19 AM   #4
binary.h4x's Avatar
binary.h4x
Quote: Originally Posted by mrhonnesty99 View Post
I think they are resistors is that what they are called it has a white # 470. is there anu special place i might find these?
They are called surface mount resistors.
Old 07-17-2007, 11:24 AM   #5
Old 07-17-2007, 11:34 AM   #6
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
www.digikey.com
Measure it with a mutlimeter but I think it's value might be 470ohm. Make sure the transistors are all the same part# before ordering. Most amps use a complimentary pair and the might not all be IRFZ44N's. make sure you replace all the transistors on the output stage an not just the burned up ones.
Good luck.
EDIT: I forgot it's a classD amp, they might all be the same part number.
System always under construction
durwood is offline   Reply With Quote
Old 07-17-2007, 11:44 AM   #7
I found the parts online and from 2 different placed the tottal was bout $22 max for all the parts including shipping lets hope it works i will keap you posted.
Old 07-17-2007, 11:47 AM   #8
mbkowns's Avatar
mbkowns is on a distinguished road
Let me know how it goes i have a JL Audio 300/4 locked in protect mode and it won't come out. Haven't pulled it apart yet but maybe thats whats up...
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
mbkowns is offline   Reply With Quote
Old 07-17-2007, 11:48 AM   #9
Quote: Originally Posted by durwood View Post
www.digikey.com
Good luck.
I found the 8 burned irfz44n, the new parts # is irfz44npbf . just in case some one got screwed like i did and the surface mount resister are part # CAT10471 from http://www.weisd.com/store2/CAT10471.html
Old 07-17-2007, 12:05 PM   #10
Car Audio Moderator
durwood's Avatar
Crack it open and have a look to see what is burned up. The 300/4 will look a bit different and might use different parts since it is a class a/b design instead of Class D.
Old 07-17-2007, 12:53 PM   #11
What exactly is the problem with the one you have i have a 300/4 that the yellow low ohm ligh stays on. one of the outputs sound really bad and the other 3 sound perfect is this you're case?
Old 07-17-2007, 12:55 PM   #12
www.digikey.com
Good luck.
I have a switchable 15/30 watt iron, would that work for this aplication? or should i get a better one?
Old 07-17-2007, 03:03 PM   #13
Car Audio Moderator
durwood's Avatar
These work great. if you have something similar then you should be fine.
Soldering Iron
Desoldering Pump (High Vacuum)
Old 07-17-2007, 03:58 PM   #14
Soldering Iron
Will the fallowing work ?
http://www.radioshack.com/product/in...entPage=search
Old 07-17-2007, 04:01 PM   #15
What solder should i use, i want it to look clean after i am done or similar to factory. or are all solders the same?
Tview t700ts - Bad drivers or bad touchscreen? HyperZulu LCD/Display 2 02-21-2007 03:00 PM
Panasonic UJ-845-B bad or did i simply order the wrong stuff? kireol General Hardware Discussion 1 12-05-2006 09:07 PM
Auto power off accord General Hardware Discussion 29 08-15-2004 08:08 AM
Bad Serial Ports on EPIA M9000 wi77iam General Hardware Discussion 6 05-06-2004 12:49 PM
how bad is composite video kderedwolf LCD/Display 4 09-23-2003 02:04 AM
