The MP3car.com Store
Thread Tools Display Modes
Old 07-18-2007, 12:04 PM   #16
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
Thing is, it's not going to help me if I don't know your car, your amps, power, how much air space you have to work with, how you're going to build that enclosure, what frequencies they will be playing, etc.
It's truely a project where you have to take everything into account, at this level it's not just pulling a box of the shelf and running with it. If you're wanting to run subs in the front, you need to look at the frequencies your components are going to play and determine if the subs will fit in there. Also need to consider if you have the hardware to properly tune such a set-up.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
Old 07-18-2007, 12:09 PM   #17
Area3's Avatar
Vehicle: 2005 Pontiac Grand Am
My Photos: (0)
Ok lets see.....
05 Pontiac grand Am
Running a 3/4th mdf sealed Sub Enclosure...
power is 4 Kinetics Batteries In Trunk
200 amp alternator
Was thinking about putting those 5 inch subs in kick panals like this...
Mainly listen to Rock.. Contempary.. Alternative.. Dance With some Occasional Rap
Hope that helps...
Now I am going to Owe you a steak dinner
Microsoft Is a Evil Empire that has corrupted a generation!
Thanks - Eric Scott
Area 3 Productions
www.myspace.com/area3
Area3 is offline   Reply With Quote
Old 07-18-2007, 12:13 PM   #18
BenOBS's Avatar
My Photos: (0)
The only things I want to point out is your gonna need a very powerfull frontstage to keep up whit 2000w of bass, especially whit a monster like this.
Depending on what you want to achieve, the xover frequancy you want on the sub and your volume target, you'll need more/less bass or mid-bass from the components wooffers... This could have a big impact on your choice.
Carputer Athlon X2 4200+
800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
All Audio Tunning done via Software. 7 channels.
CDT ES-07 - HD2 - DRT25
ED Nine.2x
ED Nine.4
ED Nine.1
ED 110v.2 (x2)
BenOBS is offline   Reply With Quote
Old 07-18-2007, 12:14 PM   #19
BenOBS's Avatar
My Photos: (0)
Oups, your were too fast Red.. hehe
Area, what about amps?
ED Nine.2x
ED Nine.4
ED Nine.1
ED 110v.2 (x2)
Old 07-18-2007, 12:39 PM   #20
Area3's Avatar
My Photos: (0)
Was Going to use this one for the front
SPECIFICATIONS:
* 100 x 4 watts @ 4 ohms
* 160 x 4 watts @ 2 ohms
* 320 x 2 watts @ 4 ohms bridged
* Damping Factor > 200 @ 4 Ohms
* 0.2v - 6v adjustable input sensitivity
* 10 Hz - 40,000 Hz Frequency Response
* Channel Separations: 75 dB
* > 90 dB S/N Ratio
* 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
* Selectable HP / LP / FULL crossover
* CH 1 & 2 Variable HP crossover 50 - 5000 Hz @ 12 dB
* CH 1 & 2 Variable LP crossover 30 - 250 Hz @ 12 dB
* CH 3 & 4 Variable HP crossover 50 - 1000 Hz @ 12 dB
* CH 3 & 4 Variable LP crossover 50 - 5000 Hz @ 12 dB
* 10 Hz - 100 Hz variable subsonic filter (CH 1&2 and CH 3&4)
* Subsonic filter allows for band-passed crossover configuration
* 0 - 18 dB adjustable bass boost
* 35 - 120 Hz Variable Bass Boost Center Frequency
* Wired Remote Control unit included
* 3x 30 Amp Internal Fuses
* 16.5" L x 9.9" W x 2" H
And this one for the sub
# 3000 x 1 watts @ 1 ohm
# 1600 x 1 watts @ 2 ohms
# 800 x 1 watts @ 4 ohms
# 0.2v - 6v adjustable input sensitivity
# 10 Hz - 350 Hz Frequency Response
# >90 dB S/N Ratio
# 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
# Linkable to another SAZ-3000D for up to 6000 watts @ 2 ohms
# 35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
# 10 Hz - 60 Hz adjustable 24dB Subsonic Filter
# 0 - 180 degree adjustable phase shift
# 0 - 18 dB adjustable bass boost with 45 Hz center frequency
# Wired Remote Control unit included
# 300-amp external fuse required (not included)
# 23.4" L x 9.9" W x 2" H
Prob Will Cross the Sub over At About 80 hz - 85 hz
Thanks - Eric Scott
Area 3 Productions
Sponsored Links
Old 07-18-2007, 01:12 PM   #21
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
If everything is going off-axis in the doors then alot of car audio specific drivers are designed for that, although there are some good combos of raw drivers that work good too. Pre-built kick panels are so-so. I mentioned in another thread that kick panels need a lot of work to get the full potential out of them. A set of pre-builts will get you in the area of good staging, but could lack midbass output.
Going with a factory door mount 2-way, you are really going to have to focus on a tweeter that can play fairly low (if the woofer is mounted off-axis) and work great off-axis if they are mounted as such.
If you have room in your sails for a large format tweet (~4" diameter) you will have some good options. Hiquphon OW, Peerless HDS, Scanspeak 6600 are some really great tweeters.
Even if you do pick up a set of car components, you might still want to consider the active crossover route vs passive. Even though passive crossovers are designed for the speaker set, they are not designed with every car in mind. And as scott mentioned, Install is about 90% of how well something is implemented and how it will sound.
Don't forget to leave room in your budget for dampening materials if accurate sound is your goal.
I'll leave you with two VERY addicting sites if you want to investigate the DIY realm or pre-packaged systems. There is nothing wrong with pre-packaged, I just prefer experimenting myself.
www.zaphaudio.com
www.diymobileaudio.com
durwood is offline   Reply With Quote
Old 07-18-2007, 01:44 PM   #22
Area3's Avatar
My Photos: (0)
I dont want this to become Complicated I just want a Simple Wow componet Set.....
After Starring At the Tymphany site It Looks All To Confusing lol
What Would I need for my own componet set?
Tweeter.. Mid Woofer and Woofer?
or Tweeter mid Driver Mid woofer and woofer?
Thanks - Eric Scott
Area 3 Productions
Old 07-18-2007, 01:58 PM   #23
Car Audio Moderator
durwood's Avatar
My Photos: (0)
Ah ok. I thought you would be into something like that. Nothing wrong with simple.
A couple other component sets to look at...
Alpine F1 SPX-Z15
Genesis Absolute 2.2
Both of those use car variant scanspeaks Too bad you probably won't be able to audition them since not too many places carry the highend stuff.
EDIT: Doh I was thinking the K2 were the utopias for some reason. That stuff I linked is probably out of your budget.
DLS has some nice sets. So does Rainbow. You will get similar performance to the focal stuff, but it's going to be dependant on tastes. I haven't heard any of these personally so I can't really rank them for you. I am only providing options.
Old 07-18-2007, 02:06 PM   #24
Area3's Avatar
My Photos: (0)
Have You ever heard the Morel Elate 3 ways?
Hmm You said alpine and Highend in the Same Paragraph
Im sorry I Just do not Like how Alpines Sound.....
I will look into thier Componets Though..
Thier cd players Aint to bad Cept the look like they came from the 80s lol
Thanks - Eric Scott
Area 3 Productions
Old 07-18-2007, 02:08 PM   #25
BenOBS's Avatar
My Photos: (0)
Have a look at the CDT ES-07 comps. 7" woofers that make amazing bass and have very good response in the upper frequancy. Plus, they can take alot of power. And if you plan to stay passive, CDT are know to have some very well calibrated xover.
ED Nine.2x
ED Nine.4
ED Nine.1
ED 110v.2 (x2)
Old 07-18-2007, 02:13 PM   #26
Area3's Avatar
My Photos: (0)
Nope let me look...
The Alpines Are very low in power
Thanks - Eric Scott
Area 3 Productions
Old 07-18-2007, 02:15 PM   #27
Car Audio Moderator
durwood's Avatar
My Photos: (0)
I heard the Morels midgrade line or one step down from the high end stuff has a better european sound whereas the high end line is tailored for the US bright tweeter market.
Alpine has it's high end stuff. Nothign funny about it. Like I said, the F1 speakers are made by scanspeak and the component set has a MSRP of $1800
Those are decent too. Those midbass drivers and I think tweeters are made by Vifa.
Old 07-18-2007, 02:16 PM   #28
Area3's Avatar
My Photos: (0)
Wow Those CDT's Are nice.... 10 Year Warrenty Very Nice!
Have you ever heard them?
Thanks - Eric Scott
Area 3 Productions
Old 07-18-2007, 02:21 PM   #29
BenOBS's Avatar
My Photos: (0)
Read my signature.. hehe
edit, and my avatar...
ED Nine.2x
ED Nine.4
ED Nine.1
ED 110v.2 (x2)
Old 07-18-2007, 02:24 PM   #30
Car Audio Moderator
durwood's Avatar
My Photos: (0)
http://car.rainbow-audio.de/products...hp?lan=2&pro=1
I have heard great things from the Vanadium Line
Sponsored Links
Trackbacks are Off
FAQ: Front Ends & Support Software for Car PC's Bugbyte The FAQ Emporium 3 09-06-2007 01:02 AM
anyone try the foobar xover plugin to run an active front stage? justxroro Car Audio 6 10-08-2006 01:05 PM
Looking for Front End Wiredwrx Software & Software Development 7 05-25-2005 04:00 PM
Sponsored Links
Ad Management by RedTyger
