The MP3car.com Store
Thread Tools Display Modes
Old 07-30-2007, 02:55 PM   #61
Area3's Avatar
Vehicle: 2005 Pontiac Grand Am
My Photos: (0)
Even know the 12s are going to be on oppiste sides of the trunk will it still have more Cone area?
Microsoft Is a Evil Empire that has corrupted a generation!
Thanks - Eric Scott
Area 3 Productions
www.myspace.com/area3
Area3 is offline   Reply With Quote
Sponsored Links
Old 07-30-2007, 03:26 PM   #62
BenOBS's Avatar
My Photos: (0)
Cone area never change, this is the Subwooffer cone size (more cone area mean more air moved by the speaker = more output whit the same power).
First you should look at the size of box you need to make your sub sound good. Personnally i would go scealed because its easier to get good sound and is take less space.
Carputer Athlon X2 4200+
800tsv - Audigy 2 ZS - PowerMate - Wifi 802.11n
All Audio Tunning done via Software. 7 channels.
CDT ES-07 - HD2 - DRT25
ED Nine.2x
ED Nine.4
ED Nine.1
ED 110v.2 (x2)
BenOBS is offline   Reply With Quote
Old 07-30-2007, 03:30 PM   #63
Area3's Avatar
My Photos: (0)
I am Doing Sealed With a 1.2 Cubic Foot Box
Thanks - Eric Scott
Area 3 Productions
Old 07-30-2007, 04:34 PM   #64
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
which tc sub are you going to go with? the tc-9 (two 12's or a single 15) will need 1.6 (the 15 will need 1.8) cu/ft
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-30-2007, 05:01 PM   #65
Area3's Avatar
My Photos: (0)
I am Going with the 3000 or the 5200 I have not yet decided...
Tc-3000 Key Features
• 160 Newtons2/watt Motor Force
• 1000 Watts Continuous Power
• 3" Anodized Aluminum Voice Coil
• Single Dish Titanium Cone
• High Excursion Tall NBR Surround
• 215 Ounce Magnet Structure
• Anti Flux Modulation Shorting Ring
• 30mm XMax
• 10" Diameter Suspension System
• Custom Cast Aluminum Frame
• Quick-Detach Top Assembly
12TC-3000
Sealed 0.5 ft3
15TC-3000
Sealed 1.8 ft3
15TC-5200
Sealed 1.0 ft3
15" TC-5200 Key Features
• 410 Newtons2/watt Motor Force
• 2000 Watts Continuous Power
• 4" Aluminum Voice Coil
• Single Dish Cone
• 390 Ounce Magnet Structure
• 30mm XMax
Thanks - Eric Scott
Area 3 Productions
Old 07-30-2007, 05:16 PM   #66
MySQL Error
scott_fx's Avatar
My Photos: (0)
wow, that's a big mama jamma. i'd still suggest the dual 12 still
M10k
My Car Pc Install
Old 07-30-2007, 05:46 PM   #67
Area3's Avatar
My Photos: (0)
See I dont know much about car Audio...
In Pro Audio Ive only worked with 15s and 18s
This is our Small System
But I think I might go with the 12s to save room!
Thanks - Eric Scott
Area 3 Productions
Old 08-01-2007, 11:02 AM   #68
BenOBS's Avatar
My Photos: (0)
Be aware that bass doesnt sound the same in a car than in a big room or outdoor. There is a big gain in the low frequancy because of the car acoustic.
Personnally, 2x10" or 1x12" or 1x15" whit around 1000w rms of amp is enought for any SQ/SQL oriented setup. Getting more is only "headroom" because it cannot be integrated easily whit the front-stage (maybe not if you got 8" mid-bass in the doors)....
2 cents from a guy that once had 2x12" and 2000w and now as acouphenes...
ED Nine.2x
ED Nine.4
ED Nine.1
ED 110v.2 (x2)
Old 08-01-2007, 11:58 AM   #69
MySQL Error
scott_fx's Avatar
My Photos: (0)
you bring up a good point. My suggestion for two 12"s was due to the fact that the trunk is totally sealed off from the cabin of the car. and the dual 10's weren't an option. I'd probably still recommend two 12's for the added headroom. I think that subs are very over rated (well the time choosing a sub... it's only taking care of a small portion of the audio spectrum) and i'm glad that he has spent the majority of his time figuring out mids/highs
M10k
My Car Pc Install
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Front Ends & Support Software for Car PC's Bugbyte The FAQ Emporium 3 09-06-2007 01:02 AM
anyone try the foobar xover plugin to run an active front stage? justxroro Car Audio 6 10-08-2006 01:05 PM
Looking for Front End Wiredwrx Software & Software Development 7 05-25-2005 04:00 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
