Old 07-18-2007, 11:09 AM   #1
Area3's Avatar
Area3 is an unknown quantity at this point
Front Stage Suggestions
Ok.....
I want your opinons.. I am new to this Car Audio stuff But Am a guru In the Pro Audio World...
I am looking for a Good Set of Componets for My Front Stage....
I Already have a sub....
• 410 Newtons2/watt Motor Force
• 2000 Watts Continuous Power
• 4" Aluminum Voice Coil
• Single Dish Titanium Cone
• High Excursion Tall NBR Surround
• 390 Ounce Magnet Structure
• 30mm XMax
• 10" Diameter Suspension System
• Custom Cast Aluminum Frame
• Quick-Detach Top Assembly
But I Am Looking for a good Componet Set To Match My Sub.
I have Been Looking at the ...
Jbl GTI Seris
Focal K2p Seris
Polk Sr Seris
Does anyone Have Any Experince With these?
Does anyone know of any Better Componets?
I am open to Suggestions..
The Audio Will be comming from My pc Via a 7.1 Card...
My Amps are Sundown Amps.
Thank You
Microsoft Is a Evil Empire that has corrupted a generation!
Thanks - Eric Scott
Area 3 Productions
www.myspace.com/area3
Area3 is offline   Reply With Quote
Old 07-18-2007, 11:21 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
The K2P from Focal is very difficult to beat.
I've not heard the GTi series first hand, but I do know that they are great components as well.
I will say that you need to listen to these components on your own first before purchasing.
Each one will have a different sound and each one might sound different to you. It all depends on which sound you like.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 07-18-2007, 11:38 AM   #3
Area3's Avatar
I was Hoping You Would Chime in...
There is no were To Listen to the Polks here in Dfw.....
And the Jbls Use Alot of Technology From the Vertec Pro Line.
But I REALLY Liked the Focals...
Will the Focals Be Able To keep up with the monster in the trunk?
Thanks - Eric Scott
Area 3 Productions
Old 07-18-2007, 12:00 PM   #4
_
hahaha- will the Focal keep up...
Those K2Ps are little monsters in and of themselves.
Again, proper tuning will work wonders.
I'm not sure of anyplace here in the DFW area to hear the polks...unfortunately. I'm not up to par on all of the shops around here.
Jan Bennett
Old 07-18-2007, 12:02 PM   #5
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
I've heard some of the Rainbow components with take a fairly good amount of input power, but I have no personal experience with them.
But, why limit yourself to passive component sets? Go active.
I can name a bunch of home drivers when properly used will sound just as good if not better than most prebuilt component sets.
Scanspeak, Peerless, Seas just to name a few.
Where are you installing the components?
System always under construction
durwood is offline   Reply With Quote
Old 07-18-2007, 12:16 PM   #6
Area3's Avatar
Cool
Well...
I read Something From Eithier You or Red About Kick Panals So Im not going to be doing that....
I plan on Installing a 5 half to 6 half inch Driver in the door and a Tweeter in the sail Panal..
but if Kickpanals Will work I Could Do Bass Driver in Door, Mid Driver in Panal w/ tweeter in panal....
I was Planning on Using the M Audio Firewire 410 For my Sound Card if that helps....
I would Really Prefer a Componet Set.. Vs Active Raw Drivers
Thanks - Eric Scott
Area 3 Productions
Old 07-18-2007, 12:20 PM   #7
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
i agree with both durwood and red. if you can't listen to the components then I would definitely suggest going the active route. you can test out drivers in your car and if you decide you don't like them you can often times sell the component for little loss (if they are taken care of and not abused) and replace them with another driver to test out. Raw drivers; even after a couple of swap outs, will cost you less then a quality set of component speakers
btw...nice choice on the sub :-)
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-18-2007, 12:22 PM   #8
Area3's Avatar
Thanks for the Advice..
Btw The Sub Does not Compare to The 75k Watt System in the shop
Thanks - Eric Scott
Area 3 Productions
Old 07-18-2007, 12:23 PM   #9
MySQL Error
scott_fx's Avatar
in that case i'd add dynaudio to your list of selections. if you find the focals a little too accurate or bright then the dyn's may be a good alternative becuase they tend to have a more laid back sound
M10k
My Car Pc Install
Old 07-18-2007, 12:27 PM   #10
Area3's Avatar
I have Dynaudio Monitors At home And I find them to Bright and Brittle....
Do you think it will be the same with there Car Audio?
I love how the Focals Are Accurate at Translating things in the audio Spectrum.
Thanks - Eric Scott
Area 3 Productions
Old 07-18-2007, 12:32 PM   #11
MySQL Error
scott_fx's Avatar
hmmm.. it could be, most people stereo type the dyn's as warm while the focals being bright but it's your ears. i heard a dyn component set (running active in a honda accord) and it sounded beautiful to my ears exactly what i would have wanted.
It could be that in car audio you often times have a tweeter mounted off axis and that may tame some of the brights...
red?? durwood?? help!
M10k
My Car Pc Install
Old 07-18-2007, 12:37 PM   #12
_
One of the things I've found is that those who complain about the Focals being bright are those people who listen to them in only one instance and most of the time they're on-axis.
The Focals need to be off axis. Most people apply conventional thought processes that work for other brands to the Focals only to find that they don't sound right.
The Focals need to be completely off axis to reduce some of the harshness, from there, it's all about tuning, as with any system.
also, I'm not sure where the comment about kicks came from?
I'm running a set of 5" Be subs in my kicks...
Jan Bennett
Old 07-18-2007, 12:41 PM   #13
Area3's Avatar
I think it is Somethuing Durwood Said About Free Air and Small Drivers
If anyone has Time this manual is a Good Read
http://manuals.harman.com/JBL/CAR/Ow...rev3_20_07.pdf
Red Would it be Wise To Do a Small 5 inch focal Sub Up Front?
Thanks - Eric Scott
Area 3 Productions
Old 07-18-2007, 12:48 PM   #14
_
it completely depends on your set-up as a whole.
We're running the Be tweeters, 3" mids, and 5" subs....if we had picked a component set this probably wouldn't have worked as well.
Jan Bennett
Old 07-18-2007, 12:58 PM   #15
Area3's Avatar
Ah Very Cool
My System Is going to be as follows....
Componet Setup in Front...
Rear Entertainment for kiddos
( headphones and monitors )
And the tc sub In a Sealed Enclosure....
in the back
if that helps
Thanks - Eric Scott
Area 3 Productions
FAQ: Front Ends & Support Software for Car PC's Bugbyte The FAQ Emporium 3 09-06-2007 02:02 AM
anyone try the foobar xover plugin to run an active front stage? justxroro Car Audio 6 10-08-2006 02:05 PM
Looking for Front End Wiredwrx Software & Software Development 7 05-25-2005 05:00 PM
