Old 07-20-2007, 10:38 PM   #1
jasonsjwou's Avatar
jasonsjwou is an unknown quantity at this point
The Headunit works w/o negative wire connected!! What's going on?
I had an alternator noise problem which I fixed with a better RCA cable. A monster's twisted pair RCA solved this problem.
But I found something weird. I disconnected the negative wire from my head unit, and it was still working. Then I reconnected the negative wire while the headunit was turned on, and it didn't make any difference.
What sort of problem am I having here?
jasonsjwou is offline   Reply With Quote
Old 07-20-2007, 10:49 PM   #2
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
it must be grounded by another connection. Is the radio is still mounted when you found this?
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 07-20-2007, 11:23 PM   #3
jasonsjwou's Avatar
This is what I know.
1. There is a noise, sounding like a static trickling noise, even when the engine is off. Whining noise is completely gone, but there is the static trickling noise even with the engine off.
2. I disconnected RCA cables from the headunit, and the noise is gone.
3. I am using a wire harness, with all the factory speaker wires attached.
4. I am using remote amp turn on from the Head unit. May be I should connect this to ACC+?
5. I draw 12V power through the wire harness. I tried to do this directly from the battery, and it didn't do anything
6. If I "pause" the head unit while it's playing the CD, the noise goes away.
I'll post more as I find more about it.
Old 07-20-2007, 11:24 PM   #4
jasonsjwou's Avatar
Well. yes... I had to connect everything to turn on and listen to the head unit... that's when I found this.
Old 07-20-2007, 11:42 PM   #5
BrokenBC is an unknown quantity at this point
The headunit most likely is grounded to the chassis and the chassis is probably screwed into something that is connected to ground.
the sound... how loud is it? your running aftermarket amps? one guess is that the sound your hearing is just the static that every deck makes... there is no such thing as silence. now depending on how your amps are set up though you might be able to turn down your gain on the amp which might help lower that static you hear, you'd just have to turn your deck up higher to get the same volume out.
the fact that you disconnect the RCA's from the deck though and have no noise then makes me think that whatever it is its comming out of the deck. Your power source/ ACC should not change any of this.
BrokenBC is offline   Reply With Quote
Old 07-21-2007, 12:01 AM   #6
jasonsjwou's Avatar
Is it normal / possible / OK to have the headunit being able to run without its ground wire connected? will it blow something up later?
Old 07-21-2007, 12:04 AM   #7
Felix509's Avatar
Felix509 is an unknown quantity at this point
bolting the deck in is a pretty good ground on some cars, as it is probably to the chassis through all the metal bracing... '
Depending on the car a deck could definably run via just being bolted in as the ground..
Have you checked that your RCA cables have no cuts where the wire could be grounding to the chassis??
best of luck with your install. .
Ours is the age that is proud of machines that think and suspicious of men who try to.
___________________________________
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
Rainbow Profi CS365 & Profi Vanadium 12"
Felix509 is offline   Reply With Quote
Old 07-21-2007, 12:18 AM   #8
rutger1413 is an unknown quantity at this point
Try a set of RCA ground loop isolators, this might work. Also double check the ground on your amp(s). You may still want to ground the deck b/c it cant hurt if you double ground it.
rutger1413 is offline   Reply With Quote
Old 07-21-2007, 02:32 AM   #9
jasonsjwou's Avatar
I think I solved the noise problem. I had the amplifier gain bit too high, so I adjusted the system again. I lowered amplifier gain, raise the volume of the HU upto about 80% (at this point the sound is not all that big) and I raised amplifier gain so that it is just a tad louder than what I can tolerate in terms of loudness.
When I did this, the trickling noise disappeared under the noise floor.
Thanks BrokenBC, your suggestion worked.
Old 07-21-2007, 01:56 PM   #10
glad I could help
Old 07-21-2007, 08:42 PM   #11
pancit175 is on a distinguished road
Just to chime in a day late, but the antenna could also act as a ground, but from what I've been told before, its not recommended to keep it that way. I know that its horrible to say this an not explain why but I can't remember everything or word it right. Something along the lines of the antenna ground is not intended for current flow. The only thing I can back this up with is that you always want to have the ground cable to be as short as possible and if you use the antenna as a ground it is more probable to accept ground noise because of the long stretch the antenna cable is. There is more to it, but I'm having a major brain fart.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 07-21-2007, 09:16 PM   #12
jasonsjwou's Avatar
I tried to take the antenna out, and that wasn't it. I think it might be grounded through the RCA cable back to the amp.
Old 07-21-2007, 09:47 PM   #13
thats also possible too. But thats even worse to let happen for too long. because that ground in the RCA cable is probably only at best 20 gauge. I've seen that let happen for too long before causeing the ground wire in the RCAs to cause a break in the line which may also cause the noise you are experiancing.
If you'd like to attempt to continue to troubleshoot this problem, I would also suggest to change out your RCA cables, or upgrade the quality of your RCAs if they are not of decent quality.
PROGRESS:
Do I Need To Beef Up My Alternator Or Anything Else chitown_16 Car Audio 23 06-19-2006 07:39 AM
lilliput touchscreen only works when connected to wall samc42 LCD/Display 0 06-08-2006 07:20 PM
Morex 60W car kit - 4 or 6 wire? MVShibui Power Supplies 0 05-09-2005 02:28 PM
where to buy wire to run from battery to inverter? hud Newbie 37 05-17-2004 08:01 PM
Attn: 15' foot 80 wire IDE works. Paid 16 buks. -DVD-ROM (Say Yes!) LESLIEx317537 General Hardware Discussion 30 02-14-2002 05:05 PM
