The MP3car.com Store
Thread Tools Display Modes
Old 07-23-2007, 09:24 PM   #16
XC-C30's CarPC Specs
XC-C30's Avatar
Vehicle: 1992 citroën AX MKII
My Photos: (0)
We're not of the spoonfeeding-kind of crowd here. So first things first: Register yourself at a dedicated car-audio forum (which mp3car is not) and take in LOTS and LOTS of reading. And if you have done so, read some more!
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Sponsored Links
Old 07-23-2007, 09:45 PM   #17
MySQL Error
scott_fx's CarPC Specs
scott_fx's Avatar
Vehicle: '99 Chevy Corvette -- '01 Volvo S60 t5 --'03 Honda CBR 600RR -- '97 Suzuki GSX-R750
My Photos: (0)
Quote: Originally Posted by XC-C30 View Post
[off-topic] WTF Scott.... Did you change speakers again? [/off-topic]
yup, probably since the last time you read about my install. this is the final choice... for now :-)
Quote: Originally Posted by BoondockSaints View Post
Also how much does the avergae tweeter/midbass (raw driver) take watt wise RMS? Im thinking about buying the Cadence amp that does 150x4 or 75x4 or if I can find a cheap sundance that does 125x4... also what ohms do must of them run? One last thing you were saying the amps need to be able to do filters? How do I know if they can do it and so forth?
raw drivers can take all different amounts of power, but dont worry about that. if you have a clean signal then you wont blow your speakers.
100 wrms @ 4 ohms is a good start. i'm running 75 wrms @ 8ohms for my mids and tweets.
cadence has a pretty decent rep
easiest thing to do is copy someone else that has/had good results.
the woofer i have comes in a few different variances you can match that up with a good quality tweet (since it has a natural roll of at 4k it doesn't have to be a large format tweeter as long as it'll play down to 4k. i think seas has a $30 tweeter that has a great rep and will match well with it)
check this out:
http://www.diymobileaudio.com/forum/...ad.php?t=16603
pair that up with a nice tweet and for about 170 bucks you'll have an amazing set of drivers...no $200 set of passives will come close (properly installed of course) and yes...definitely deaden the doors.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-23-2007, 10:24 PM   #18
My Photos: (0)
Those look real nice... Im assuming they will blow the crystals out of the water lol... I think I saw someone say that they were a little rough on the mid and wouldn't be recommended for a 2 way. Im tempted to get this and a tweet set to compare between the crystals and this then sell whatever one I don't want. But I only got 350 bucks and I don't think I get payed for another week and half. I dunno if I would have enough for that and tweeters and an amp that could power both. Still gotta sell my mag lol...
Would it be a terrible idea to get this and a tweet to see how I like it vs the Crystals? Or is this just gonna be a waste of my money?
BoondockSaints is offline   Reply With Quote
Old 07-24-2007, 12:40 AM   #19
MySQL Error
scott_fx's Avatar
My Photos: (0)
first offer him less :-) i got mine for 75 bucks each brand new. mine are the same exact drivers but with fiberglass cones that are a little easier to work with. you may want to hold out for some of those or maybe check out the Vifa XG18.
i've heard some good things about the seas neo 27TAFNCG tweets.
here is a breakdown of some high quality drivers by forum member npdang IIRC (from www.diymobileaudio.com)
Quote:
Since I see this question asked so many times, I decided to write a guide that touches on some of the more popular 7” drivers. I know everyone likes ratings, so I made an attempt to rate each driver from 1 to 10, 10 being best.
Value – Overall, how does this driver perform given it’s price?
Build – How sturdy and robust is the driver’s construction? Does it offer advanced features such as cone technology, suspension, frame, etc.?
Midrange clarity – How realistic does this driver sound? Are details rendered with absolute precision?
Bass performance – How clean is this driver at producing bass? How much bass can this driver provide?
Ease of use – How simple would it be to achieve optimal results with this driver? How easy would it be to integrate to a wide variety of tweeters?
7” mid/bass:
Seas RNX drivers – Comes in many flavors, but are essentially the same driver. The /p in the model# refers to a phaseplug. Model #’s are P for poly, L for aluminum, G for fiberglass, CA for paper. For example L18rnx/p refers to an aluminum cone with phaseplug.
Poly – Unlike Dynaudio for example, the Seas poly cone is a pure poly cone and unblended with mica or any other stiffening elements (IIRC). This yields a very well dampened cone that provides a smooth frequency and extremely forgiving nature at the expense of detail. Special note, the P18rnx/p is the only model to use the latest “adaptive surround” which is used on Seas higher end Excel drivers. The adaptive surround provides greater dampening at higher frequencies for a smoother response, and less dampening in the lower frequencies.
Aluminum – Provides the best detail retrieval, but has significant upper end breakup which should be attenuated to reduce coloration and distortion. Can be a difficult driver to work with, and should ideally be used below 2khz necessitating a high performance tweeter.
Fiberglass – This is the best compromise between detail and warmth. Robust sounding, but not overly laid back or heavy. Has excellent top end extension that will mate easily to any tweeter and requiring very little filtering up top. The only downside is that this unit has been discontinued and could be hard to find. Solen.ca usually has some stock.
Paper – A very warm, smooth, robust sounding midrange. Generally considered the most neutral sounding driver of the three, although detail retrieval is nearly as bad as the poly cone. Definitely has more character and presence than the poly. Good top end extension means this driver mates quite easily to any number of compact tweeters.
These drivers represent an amazing value. Seas is a brand that’s well known for its unit to unit consistency, build quality, and quality control. This sets them apart from many other brands such as Tang band, Hi-vi, etc. in my experience. Another strong point is the very low mechanical noise, and the whopping 22mm peak-peak throw. Very few drivers can match this level of output, and it’s probably the maximum limit you can achieve in a mounting depth of just 3”. Although many drivers will advertise high xmax numbers, they sometimes have so much chuffing, clanking, and complaining that it’s all but unusable. Clean, brute force excursion is the name of the game here. Typical in-door bass response offers flat response to 30hz.
Value: 7
Build: 7
Midrange clarity: (Poly 4, Paper 5, Glass 6, Aluminum 7)
Bass performance: 8
Ease of use: (Poly 10, Paper 7, Glass 9, Aluminum 2)
Peerless Exclusive 830883
Another top performer. Build quality and unit to unit consistency is top notch and on par with Seas. Mechanical noise during high excursion is very low. Amazingly, distortion performance is among the best rivaling that of the Seas Excel, which is often considered the pinnacle of low distortion drivers. A bit less bass output and brute force excursion than the Seas RNX series, but at mid and lower output levels slightly cleaner as well. I would describe the tonal characteristics as dry, but with much of the robust nature and presence of a good paper cone. Clarity and realism is exceptional. Upper end response does need some contouring, otherwise the driver can sound shouty and aggressive. Definitely the driver for someone looking for the best clarity and enjoys the sound of a well executed paper cone.
Value: 9
Build: 8
Midrange clarity: 8
Bass performance: 7
Ease of use: 7
Dayton rs180
Dayton drivers come in at a very low price point making them the most easily affordable driver in the bunch. I find that the build quality is good, although unit to unit consistency can be anywhere from fair to good in my experience. Detail and clarity are very good, and an amazing performance even at a much higher price point. I find total bass output to be slightly less than the Peerless, and about comparable in performance. Mechanical noise performance is good, but not excellent. Where this driver really shines is it’s midrange clarity, which comes very close to what I would consider the reference driver, Seas Excel magnesium cone. It does sound slightly more polite, laid back than the Seas magnesium cones however. Very strong, multiple breakup modes in the upper end make this driver difficult to use especially in minimizing coloration and mating to a compact dome tweeter.
Value: 10
Build: 7
Midrange clarity: 9
Bass performance: 6.5
Ease of use: 2
Vifa XG18
One of my favorite fiberglass cone drivers. Do not confuse this driver with the XT wood pulp driver also from the Vifa line. Clarity is somewhat noticeably better than the Seas RNX series, as in less haziness and softness to the presentation. Upper end extension is smooth and extended, and should mate easily to any number of compact tweeters. Unfortunately, not a strong bass performer. The inverted multi-roll surround smoothes the frequency response as well. One of the best drivers for someone who doesn’t posses a lot of tuning capability.
Value: 6
Build: 7
Midrange clarity: 7.5
Bass performance: 4
Ease of use: 10
Focal 6w4311
It’s unfortunate that Focal has left the diy market. A very difficult driver to find nowadays, but still deserves special mention. The 6w4311 possesses a unique blend of clarity and character that make it one of the best drivers that I’ve heard midrange wise. It’s nearly similar in clarity to a metal cone, but almost completely absent of any metallic coloration or fatigue. Mediocre non-linear distortion performance and motor design hampers what I would consider to be one of the most advanced cones available. The driver requires modest filtering up top, but can still be mated easily to most compact tweeters.
This version differs dramatically from the 6w2 used in the retail car audio component sets, namely in that it uses the latest generation cone…. which is stiffer, thinner, and bears a striking similarity to the Audiom line, and also features a flat spider instead of a cupped spider design. You will also notice that this version has a metal phase plug, but without the bullet shaped cone at the top. Bass performance is not quite as good as the 6w2, and more on par with the Vifa XG.
**Edit - Zalytron and Orcadesign now sell a "b" version of the 6w4311 that's shielded. With a higher qts it's more suitable for car door use. Another notable change is the cone is no longer a constrained layer of foam between two glass sheets, but an even thinner cone with a single layer of glass and foam underneath.
Value: 6
Build: 8
Midrange clarity: 8
Bass performance: 5
Ease of use: 6.5
Seas Excel W18 Magnesium cone
The reference driver for those seeking the absolute best resolution, accuracy, and clarity. The magnesium cone of this driver is remarkably stiff, and coupled with a world class motor design and low loss suspension offers amazing realism and detail. A somewhat older design, bass performance is good but not up to par with the more recent designs such as the RNX series. Although difficult to work with, the single well defined breakup mode and ruler flat response makes it easier to deal with than most typical metal cone drivers.
Value: 6
Build: 9
Midrange clarity: 10
Bass Performance: 6
Ease of use: 4
Seas Lotus rw165
Similar to the Seas Excel w17, an older generation variant of the W18. It features a shorter voice coil, as well as no ventilation under the spider or pole vent. This driver comes with weather treatment on the cone which makes it appear black rather than white, and although it’s somewhat restricted design prevents maximum airflow through the driver it also serves to protect the driver from moisture and dirt entering the motor. It’s also one of the only 4 ohm drivers that Seas makes, with significantly higher q and fs values gives this driver more snap in the bass region, albeit at the expense of low end extension. It’s also nearly half a cm shallower than the RNX series drivers.
Value: 4
Build: 9
Bass Performance: 5
Ease of use: 4
Seas W18NX
The pinnacle of Seas driver design. Utilizing a higher excursion motor than the W18, Seas replaces the stiff magnesium cone and low loss suspension with a high tech adaptive suspension and stiff, Nextel treated paper cone. The result is a stiff cone which offers some measure of internal dampening reducing coloration and allowing for more flexible upper end crossover points. The result? Better bass performance than the RNX series, and midrange qualities nearly similar to that of a metal cone driver without the associated heavy ringing and breakup.
Value: 7
Build: 10
Midrange clarity: 9
Bass Performance: 10
Ease of use: 6
Scan-Speak Revelator 18w/4531g
One of the most highly regarded and popular driver in its class. The Revelator offers an exceptionally high output/low distortion motor design, along with a well ventilated chassis and unconventional slit paper cone. This is one of the best examples of a paper cone driver available. Renown for having extremely low coloration and a most natural presentation, combined with good top end extension and ease of use.
Value: 6
Build: 9
Midrange clarity: 8
Bass Performance: 9
Ease of use: 8
Usher 8945p
An improved clone of the infamous Scan-Speak 8545. Famous for it’s dark, warm, rich sound. Some describe it as velvety. Quite a good mix of detail and warmth. Some minor frequency response issues to worry about, but nothing severe. Solidly built, with a low distortion motor and great bass output. Magnet size is large.
Value: 6
Build: 8
Midrange clarity: 6
Bass Performance: 7.5
Ease of use: 7
http://www.diymobileaudio.com/forum/...ht=Vifa+XG1 8
have fun reading :-)
M10k
My Car Pc Install
Old 07-24-2007, 04:40 AM   #20
My Photos: (0)
Scott really appreciate the help here, started reading that but gotta be at work in 5 mins, will continue when I get home. Will ask more questions then .
Sponsored Links
Old 07-24-2007, 10:31 AM   #21
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
Boondock-I thought you were over at DIYMA? Really, take the time to read up on the reviews by npdang and shinjohn. There reviews are amazingly helpful and they have experimented with so many drivers. When you search, do an advanced search and makes ure you put their username in an select "threads started by".
Scott already gave you the big 6.5-7" midbass comparison. and shinjohn has a massive tweeter review.
If you want a combo that "just works" very well together, it would be hard to beat the Seas CA18RNX tied together with the seas neo 27TAFNCG tweets at that price. The combo is just over $200.
I had those L18's and they are a great choice too, I just think the CA18 is more fool proof and easier to tune and work with.
Two other midbass drivers you might want to consider, one of them is in that review scott posted. Here are two drivers I have been looking at. The 6.5" Aurum cantus would be a good choice too. All three drivers are on sale right now. My preference would lean more towards the Usher. Npdang reviewed it and Zaph reviewed it-both seemed to like it. See my link:
http://www.diymobileaudio.com/forum/...ad.php?t=16625
As far as amp power, try to go with something that will give you at least or approx 50W @ 8ohms (so a rating of 80-150W @ 4 ohms works or close to it). Your tweeters won't really need as much power as your midbass since they are more efficient and typically can handle less power thermally.
durwood is offline   Reply With Quote
Old 07-24-2007, 08:22 PM   #22
My Photos: (0)
Alright guys Im looking through these and it seems some of my best choices would be the: W18NX, Vifa XG-18, Glass or Alluminum RNX, but this is just preliminary. I still wanna look more into it which I am, but first wheres a good place to see the prices for all these... the only place I can seem to find that carries Seas is Madisound... if yall got a good place to look at prices that would be great.
Then as far as the amp goes... are all amps capable of 8 ohms even if they dont list it? (sorry for the nubness)
And durwood I am on DIY but just seems to be a slow response on there... thanks again guys this is the most response I have got on any of the 4 or 5 forums I posted this on.
Old 07-24-2007, 10:06 PM   #23
Car Audio Moderator
durwood's Avatar
My Photos: (0)
Amplifiers can handle higher loads no problem, it's actually easier on them then lower loads (ohms). And don;t worry too much about less power going to a higher ohm load, the efficiency of 8 ohm drivers is actually makes them equivalent to 4 ohm speakers essentially.
More Tweeter reviews
Places to buy raw drivers, there are a few more places out there, but this is where you will find the bulk of them.
www.madisound.com
www.solen.ca (canada)
http://www.zalytron.com/
www.timbre-audio.com
www.partsexpress.com
http://www.acoustic-visions.com/
Responses are not normally slow on DIYMA, it's just that 2-way setups have been discussed quite a lot, so people don't respond to those types of threads as much. It's more of a point in the right direction because it's more fun when you can learn it yourself. Otherwise all you will get is differing opinions anyway.
here are some more good threads to read. Some are very indepth and will take some time to digest if this is all new to you. Just be patient. If you are willing to learn it can be fun and could save you money...or not if you like to experiment.
Crossovers
8ohm vs 4 ohm drivers
Deadening
Advanced speaker placement-imaging and staging (physics of sound in a car)
Old 07-25-2007, 01:24 AM   #24
MySQL Error
scott_fx's Avatar
My Photos: (0)
great links by durwood
if you're going to get the f/g rnx solen.ca may be your only choice unless you get it used. if you decide that route (which i suggest since they are supposed to be pretty easy to blend with) get the drivers asap because they dont make them anymore.
they are about 150/pr shipped IIRC. the vifa's are around the same price but the w18nx are a lot more
M10k
My Car Pc Install
Old 07-25-2007, 04:09 AM   #25
MySQL Error
scott_fx's Avatar
My Photos: (0)
i just ran across this:
http://www.diymobileaudio.com/forum/...t=16642&page=3
maybe another option to confuse you
M10k
My Car Pc Install
Old 07-25-2007, 08:58 AM   #26
Car Audio Moderator
durwood's Avatar
My Photos: (0)
Yes the Seas Reed version of the RNX series looks good. They did some things to lower distortion in that driver compared to the other versions of the RNX series.
Just so you know, the aluminum version is very hard to use in a 2-way setup because of the cone causes some weird things to happen in the response curves up in the higher frequencies. It's better used in a 3-way IMO unless you are ready to do some serious tuning and the tweeter has to be able to play lower down in the 2-2.5Khz region.
Old 07-25-2007, 09:15 AM   #27
XC-C30's Avatar
My Photos: (0)
maybe another option: HDS 810921 + 830883.... smooth curve, laid back sound, but able to produce a firm kick in the right enclosure. The tweeter is pretty smooth aswell, no sharp ends or boosts in the high-range (didn't you review this tweeter one, durwood?)
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 07-25-2007, 09:44 AM   #28
Car Audio Moderator
durwood's Avatar
My Photos: (0)
That is a great tweeter (but I didn't review it), and I plan on using it in my fiances car (if she lets me), but since it is a large format tweeter it won't fit in my car. It's a great value tweeter with excelent characteristics. It competes with tweeters that are 3-4 times it's price. The mid would be a good one too, actually almost any mid would work well with that tweeter, it's very versatile.
Old 07-25-2007, 12:43 PM   #29
My Photos: (0)
Thanks guys this is really helping Im gonna read alot more tonight then get to you... I need to finish fiber glassing my sub box before anything though. So Im off to walmart to buy some more aluminum foil... and then once Im done fiber glassing I will get back to you guys! Thanks again.
Old 07-28-2007, 09:12 PM   #30
My Photos: (0)
Alright guys sorry it took so long to get back my internet had been acting up and got caught up in work and stuff... Well Im thinking either the fiberglass or tweed RNX 7" mids are going to be my best choice. My question is if I do decide to go 3 way later, would these be a good choice? Or is it even necessary? Im going to take another look at the reviews for mids again, especially the ushers and the ACs, but as far as price and quality go these seem like the top choice so far.
Tweets I really haven't got a chance to REALLY look into but I figure I need to match the tweets to the mids so I should do that after I choose my mids. The Seas 27TAFG/C is probablly a good choice for these.
Then amps... still looking at them at the moment and I will post up more links as the night progresses but do you think any of these are decent?
Lanzar Amp 1
US Amps 1
Still looking but are there any suggestions yall could make? On particular amps to get or to avoid or even brands to get or avoid?
Then I still kinda need an idea of what wires I should purchase... I can't seem to find the list that I found previously but Im still looking.
Once again sorry for the long pause in this, but as always all help is appreciated.
Sponsored Links
vB code is On
Trackbacks are Off
Tachometer questions. nricciar Hardware Development 11 08-04-2008 11:04 AM
TM-868 Questions gadgetbuilder Input Devices 3 06-19-2006 09:15 PM
Yet another newb, And yet another string of questions. j4yj0hn Newbie 6 01-28-2005 10:37 AM
Power supply questions miztahsparklez Power Supplies 12 01-24-2005 11:13 AM
Newbie questions...system proposal, etc...(first post) Subliminal Newbie 9 10-07-2003 08:19 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
