Old 07-28-2007, 06:07 PM   #1
skater_freak90 is an unknown quantity at this point
somthings wrong with my system
i can figure out wats wrong. the other day i got a 1000 watt sony xplod amp and a lightning audio 10'' and i had the mtx audio 10''. i hooked it all up with a wiring kit and then i turned the car on it started beating but when i went to turn it up for full bass the amp turns off and it gets really hot . i checked the ground wire and stuff it all seems to be ok . and now its turning off soon as i turn it on .(I NEED SOME HELP)
skater_freak90 is offline   Reply With Quote
Old 07-28-2007, 06:24 PM   #2
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
you wired the subs incorrectly (most likely) do a search on how to wire a sub (parallel vs. series)
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 07-28-2007, 09:54 PM   #3
kostyanj is an unknown quantity at this point
Definitely true, your subs prob can't handle the resistance (ohms) that you're putting to them. They start overheating and the amp shuts down.
www.computer-forums.net
kostyanj is offline   Reply With Quote
Old 07-28-2007, 10:18 PM   #4
MySQL Error
scott_fx's Avatar
you got it a little mixed up. the amps can't handle the impedance of the subs, the amp starts to overheat and shuts down.
M10k
My Car Pc Install
Old 07-28-2007, 11:47 PM   #5
You're right, that's what i meant to say. I've been thinking about resistance all day (re-wiring my current system).
Old 07-29-2007, 03:54 AM   #6
MySQL Error
scott_fx's Avatar
i figured as much :-)
M10k
My Car Pc Install
New EWF + MinLogon and CF instructions SFiorito WinNT Based 313 10-21-2009 07:55 PM
2001 C5 Corvette Car Computer/Audio System modena0 Show off your project 5 09-07-2006 10:18 AM
Ground audio system to battery?? eddie Car Audio 7 05-30-2006 03:34 PM
Honda Accord System Theory GeoLogic General MP3Car Discussion 10 04-03-2006 01:43 PM
Escalade PC and Audio System Install accentsound Car Audio 3 11-02-2005 12:50 PM
