Old 08-02-2007, 10:34 PM   #1
Megalomaniac's Avatar
SQ rebuild, have some questions on securing wires
I am planning on doing a complete new rebuild SQ style. And I am wanting to purchase some wire loom. I was looking into techflex(clean cut), I have a few questions.
1. Whats a good online(trusted) or retail store to get wire loom, doesnt have to be techflex, but it needs to get the job done. I am trying to avoid that plastic loom you can get at HD if all possible.
2. to mount them to the floor of the car, is everybody using those zipties with screw set thing?...what if I use tunnel tape?
3. In my accord im looking it doesn't seem like i can find a place to hide the wire going straight down without it showing..hump? Im thinkin to run the wire next to the center console path type channel. How do you manage to hide your wires?
4. Heat shrink tubing. im looking to buy assorted colors to keep everything color coded for ease. I think im going to get that from Parts express, unless you know of a better shop?
5. Thank You in advance, i hope Jan chimes in.
Megalomaniac is offline   Reply With Quote
Old 08-03-2007, 12:12 AM   #2
MySQL Error
scott_fx's Avatar
i believe i got mine from parts express awesome e-retailer
gaffer's tape is what i used under the carpet
i find a corner to run my wires along, try to find a path with the most obstructions and run it under that.
parts express is amazing
kiss *** :-)
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 08-03-2007, 06:06 AM   #3
Car Audio Moderator
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
scott pretty much got you covered.
If you have a fry's local to you they carry techflex and all sorts of heatshrink and in different colors if that is what you want. Or just get it from PE. They are cheap. www.selectproducts.com has pretty much everything too, but the cost more.
For securing cables without drilling screw holes I recommend those plastic cable tie mounts with adhesive backing. You should be able to find them at local hardware stores or anywhere online. Then just secure to it with a zip-tie.
http://www.partsexpress.com/pe/showd...number=080-515
durwood is offline   Reply With Quote
Old 08-03-2007, 10:26 AM   #4
i like the gaffers tape idea , but i figured tunnel tape would have been better for securing wires, either way no residue.
Old 08-03-2007, 12:32 PM   #5
Area3's Avatar
Ahh Gaffers Tape Mans Best Tool!
I use Rose Pro Gaffers Tape at Work and Its AWESOME!
I Recommend either One of these...
http://www.rosebrand.com/product873/...=1&info=Safety
http://www.rosebrand.com/product914/...=1&info=Safety
For Shrink Tubes Fry's Is always the best place..
The one at George Bush and 75 Is were I get my Stuff!
And Um I do not know what to tell you about hiding Wires But if you need Help Im just down the Street
Microsoft Is a Evil Empire that has corrupted a generation!
Thanks - Eric Scott
Area 3 Productions
www.myspace.com/area3
Area3 is offline   Reply With Quote
Old 08-03-2007, 01:27 PM   #6
Dam thats an excellent price for 4" gaf tape. I've been spending $20 a 2" roll from guitar center and altex for almost 2 years now. sad isnt it. thanks for the website. I was looking for a good site for that caution gaffers tape, i needed it for work (videographer).
Same Frys i go to as well. I've always seen those longa$s heatshrink tubing but never much paid attention to the price, any idea how much it costs?
Old 08-03-2007, 02:53 PM   #7
MySQL Error
scott_fx's Avatar
you can tell who's 'in the industry' based on if they know wht the hell gaffer's tape is
M10k
My Car Pc Install
Old 08-03-2007, 03:31 PM   #8
lol yeah, none the less gaf taper > duct tape
edit: what are rules about looming? what if i loom to the point where the tunnel tape takes over?.would i get points taken off?
Old 08-07-2007, 11:48 AM   #9
Area3's Avatar
http://shop4.outpost.com/%7BcbXXyx+z...x=0&submit.y=0
There you go!
Thanks - Eric Scott
Area 3 Productions
Old 08-07-2007, 12:20 PM   #10
_
WireCare.com
I swear we should get kick backs from those guys as much as we recomend them. Unlike other places, they sell EVERYTHING, not just PET loom, but the fire retardant stuff that we use, self extinguishing, 3:1 heat shrink, etc.
D-rings and the metal alternative. Tape isn't such a good idea if you're going to be judged. They want to see it secured to the car, not just taped to the car.
In preexisting wire cavities, under carpet, get creative. Pull up the factory pad under the carpet if you have to. Believe me, you don't want that wire to roll around under your feet.
Yeup - Wirecare...go 3:1 NO MATTER WHAT. Yes, it's more expensive, but it gives a MUCH more professional look thank 2:1 and it's more flexible than the 2:1 stuff. Fry's does NOT sell 3:1 and their product is MUCH cheaper than the good stuff that wire care sells. It's not as flexible and is a much lower quality. The black shows creases and discolors on creases much too easily. It's much more pliable from wire care. We've had to use the Fry's crap in a pinch before...heck, we used it before we knew about wire care...I'd rather wait for a shipment from wire care before I use the Fry's crap in the car again.
You're welcome!
Let us know if you have any more questions.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 08-07-2007, 12:39 PM   #11
that wirecare site looks awesome! nice find.
Would you happen to have a chart for comparison as to wire guage to size in inches, im a bit confused on the sizes, i dont want to have to bust out a ruler...if you cant then thats okay.
Old 08-07-2007, 12:57 PM   #12
Raw Wave
TruckinMP3's Avatar
Gaffers tape is better than Duct tape
The adhesive is not the same. Gaffers tape is made to leave less or no residue from the adhesive.
Note: I am not in the 'industry' just sort of informed
TruckinMP3
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 08-07-2007, 05:06 PM   #13
_
Either way, tape in general. will not get you points for being secured in the car as it's not adequate.
As for wire size (for regular PET or the like...not the Fiberglass or the Nomex stuff):
The web site will tell you
1/4" on 8 gua I believe, but we didn't do much 8 gua. 3/8" on 4 gua and 3/4" on 1/0 is what we've been using. That's on the clean cut products from them, that stuff doesn't have quite the expansion rate as the regular (it's also more $$$) but it looks more professional...just like the 3:1 heat shrink.
Jan Bennett
Old 08-07-2007, 05:09 PM   #14
_
I'd also like to note that you can look into the zip-ties that have a opening in them for a screw. You can use those and it might be cheaper. I know that Fry's and Altex has these for good prices.
Jan Bennett
Old 08-07-2007, 05:45 PM   #15
thank you for the help, i'll probaly have a big order to place with that site next week
Will someone be willing to answer a few questions about the Vietnam War for an essay? guitar333 Off Topic 6 05-25-2005 11:53 AM
Questions about extending wires from Xenarc PDiddy Newbie 10 02-13-2005 05:00 PM
Carputer SQ questions... tweek Newbie 3 08-11-2004 04:27 AM
To splice or not to splice - stock speaker wires that is... The Grinch Car Audio 16 07-30-2004 12:46 PM
Newbie freebie(my setup: suggestions + questions) cadence117 Newbie 4 04-18-2004 10:50 PM
