Old 08-21-2007, 02:30 AM   #1
Mystic_Shinobi is an unknown quantity at this point
Carputer Damage from Subwoofer?
I've been searching the forums but I can't seem to find a thread discussing this. I'm in the process of planning out and building a carputer for a Nissan 240sx I'll be receiving in a few months. I planned on having the carputer in the trunk along with the sub and amp/s. The sub is going to be a 15". I planed on having the whole trunk custom fiberglassed with spots to mount the amp and carputer next to it. Will the vibrations from the sub damage the carputer with it being so close to it, or should it be ok? Do I need to add any kind of vibration damper and if so what would work best? Sorry if this subject has discussed before, I tried seaching different strings but couldn't find the answer I was looking for. If the the placement of the carputer isn't idea, any suggestions would be greatly appreciated. TIA
Mystic_Shinobi is offline   Reply With Quote
Old 08-21-2007, 08:02 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
You're not searching very hard (or very smart), then.
This is something that has been brought up and discussed at length many times over.
Sub vibrations could damage a hard drive, certainly. As far as the solid state hardware (motherboard, etc.), I'd be concerned only about components coming loose, which isn't a good thing, but not the end of the world, typically.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 08-22-2007, 04:40 PM   #3
pancit175 is on a distinguished road
And I believe that there are some hard drives (other than solid state) that are advertized as extreme enviroment, where it can take more cold, heat, and vibration than the average hard drive.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 08-22-2007, 07:25 PM   #4
Megalomaniac's Avatar
Megalomaniac is on a distinguished road
as long as you mount the HDD nothing should happen. people with 150+db substages have never encountered problems. heck i've seen a 161db spl van with a carputer that took the abuse like a champ...although it was just a burp
Megalomaniac is offline   Reply With Quote
Old 08-23-2007, 01:19 AM   #5
k, thx for the info, like i said, i searched but apparently not the right strings. sorry for another thread that's been discussed already.
Old 08-24-2007, 03:14 PM   #6
mgithens is on a distinguished road
keep the HD as far from the sub as possible... I kept getting the master boot record corrupted on various hard drives when the sub was less than 1 foot away... this was a 200watt sub, small magnet and moderate volumes... seemed to blitz on road trips...
EPIA SP13000, 512 DDR400, Seagate 300GB, Belkin PCI 802.11g w/external antenna, Holux GM-210 GPS, XM Direct w/ serial, Dlink FM, Opus 120 p\s, Rockford P4004 amp, Xenarc 7" VGA touchscreen custom mounted in double din spot -- see pics and write up here!!
mgithens is offline   Reply With Quote
Old 08-24-2007, 03:33 PM   #7
That might be a bit alarmist....
I think that keeping the HDD a reasonably safe distance from the sub is certainly a good idea...
Old 08-26-2007, 09:55 AM   #8
paragraph's Avatar
Location: Friggin' New Joysee! Sirius Station: 27 HardAttack
paragraph is an unknown quantity at this point
First off, a sub magnet isn't going to produce enough of a field to wreck a hard drive, because of the manner they are made hard disks are Faraday cages, so it would take some crazy amount of magnatism to wreck a hard drive.
Vibrations however are more likely to cause a problem.
When you mount the hard drive i'd try and use a hard drive cage with vibration dampning (eg: the kind that come with thermaltake cases, they are just little rubber gromits that allow the hard disk to transfer shock onto them.) http://www.newegg.com/Product/Produc...sunami%2bdream check some of those pictures, i'm sure you can rig something like that up with what you have.
It should also be said that 2.5 and 1.8 inch drives are much more resistant to vibration than a 3.5in drive since they are designed for mobile applications.
the worst that can happen is you lose the hard disk. So i'd ghost an image before it leaves the bench and if it does happen to die you have a copy of it for the next hard drive.
'93 Camry - Work Log
Progress (Slow and Steady)
Phase 1: Planning and Software Procurement
Total Cost So Far: $75
Free Laptop Parts (DVD ROM!)
paragraph is offline   Reply With Quote
Old 08-26-2007, 03:04 PM   #9
I agree that a subwoofer's magnet isn't going to cause a problem, the fixed magnet is a steady state solid magnet and that would have little affect, BUT... I totally am 100% aware that the electromagnetic forces that cause the speaker to move are plenty adequate to affect a hard drive...
I am not speaking about a theory, I am 100% positive that my setup corrupted the master boot record. I used two different hard drives and had the same problem. The corruption occurred on long road trips - without fail!! So every weekend we would set out for skiing and about 1/2 the way there, the computer would start to act up - I would attempt a reboot and it would fail. I switched cables, power supplies, motherboards and ram. I tried a maxtor and a wd drive - same results. I moved the sub and it hasn't happened a single time - and I am still using one of the same hard drives!!
so paragraph, I'm not trying to be rude. I am just forewarning based on my experience... I will say this thought -- why risk it?? Put three feet between a sub and a hard drive versus boxing them all up... i have had plenty of success with that much space.
Carputer wont power up once Amp is installed Legrath Newbie 6 03-20-2007 11:16 PM
Carputer Shock Absorber bcholagh General MP3Car Discussion 1 08-09-2005 12:09 AM
Carputer integration with HUGE car audio system, help please septicdeath Newbie 19 12-04-2004 06:37 PM
Good time to buy carputer components? Linus General MP3Car Discussion 19 11-25-2004 09:57 PM
semi-newb, need help planning for carputer in a Mazda3 Stealth915 Newbie 9 10-23-2004 03:25 AM
