The MP3car.com Store
Thread Tools Display Modes
Old 09-04-2007, 11:42 AM   #1
bambam's CarPC Specs
bambam's Avatar
Vehicle: 1995 Mitsubishi 3000GT SL
My Photos: (0)
Carpc sound to HU...5.1 or 2/4 speakers?
I currently have a carpc system built on a ASRock 775i65G motherboard and am using the onboard sound that feeds into my Panasonic CQ-C9801U headuinit. I think the system sounds really good but my buddy says it would sound even better if I was to use the 5.1 digital sound from my board. Currently, I am only using the 2 speaker setup.
My question is this, do you think he is right? And if so, what would be the best way to hook it up? Right now, I have a single line sound connection coming out of the baord that splits into the left/right rca connections of the headunit. If I was to turn on the 5.1 digital on board, that would mean 3 connections coming out of the board (front/rear/sub)...how would you feed that into the left/right rca connections on the headunit?
As always, thanks in advance to all who respond.
bambam is offline   Reply With Quote
Sponsored Links
Old 09-04-2007, 11:53 AM   #2
Yevmeister's CarPC Specs
Yevmeister's Avatar
Vehicle: 2006 Jetta, 1988 Jetta Carat 16v
My Photos: (0)
you can't you have run (front/rear) directly into the amp, and middle/sub into mono amp or however your amps are set up.
it would sound 300 times better if you bypass the headunit
Yev
R. T. F. M
Yevmeister is offline   Reply With Quote
Old 09-04-2007, 11:58 AM   #3
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
You need dedicated amplifiers for each output. You can't connect it 5.1 the way you are thinking. I won't go into a lot of details but is your music recorded in 5.1? Are your speakers in optimal locations for surround sound?
Just some things to think about. To say it will sound better in 5.1 vs stereo is not true, there is no correct answer to that question.
durwood is offline   Reply With Quote
Old 09-04-2007, 12:02 PM   #4
bambam's Avatar
My Photos: (0)
Thanks, that sounds logical.
I did forget to mention that the HU feeds the front/rear speakers and the HU sub out goes to a mono amp that feeds my 2 10" subs so the mono amp is the only amp I have.
Thanks again
Old 09-04-2007, 12:04 PM   #5
v8 scimitar's CarPC Specs
v8 scimitar's Avatar
Vehicle: 1971/Scimitar/SE5, Ford Focus TDCI
My Photos: (0)
Should you all depends on if you watch movies with 5.1 in the car. If its mostly MP3 WMA basically music then I wouldn't bother. Music generally doesn't have the channels in it anyway so any 5.1 you get from it is fake. Sometimes it works sometimes it sounds terrible it all comes down to the drivers you have and what you use to play them with.
Visit my site V8 Scimitar
SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit.
v8 scimitar is offline   Reply With Quote
Old 09-04-2007, 12:09 PM   #6
warnockm's CarPC Specs
warnockm's Avatar
Vehicle: 2002 Subaru WRX
My Photos: (11)
remember speakers are blocked by seats, so you won't get good spatial effects. passengers in the back seats would only hear rear effects. Stereo is the best way to go in a car.
Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
warnockm is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
FAQ: Why not Home PC speakers for the car? RedGTiVR6 The FAQ Emporium 22 03-05-2008 03:35 PM
Excellent sound from speakers, very quiet sub xraycat Car Audio 3 07-10-2007 03:38 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 11:19 AM
WRX Premium Sound CarPC hookup bdirty Car Audio 0 02-14-2007 01:58 PM
Sound Quality w/ HU? ouikikazz Car Audio 12 07-17-2006 08:06 PM
Sponsored Links
Ad Management by RedTyger
