Newbi Question on Audio
Hey guys,
I am in the process of gathering everything up to install my carpc. I already have my computer (see below for specs), wireless keyboard and Sirius satellite modification kit. What do you guys recommend me using to send an audio signal out? I was looking at the Turtle Beach Audio Advantage Roadie USB audio adapter but after doing more research Im not sure it will work any better than their Audio Advantage micro. I would really like two sets of outputs (front and back). Does anyone have any recommendations on what I should use? Im stuck.
(My audio system: (1) KX600.4 amp driving (4) 6x8 Kickers with 1 tweeters, (2) KX1200.1 amp driving (4) L5 Dual Voice Coil 12s)
Enclosure
Automotive grade PC enclosure
Tough design with 5.5mm black anodized extruded aluminum
Integrated case fan for proper cooling
Four integrated mounting feet/tabs for installation onto any flat surface
Dimensions & Weight
8.4"(W) x 10.1"(D) x 2.25"(H)
~4lbs
Operating Temperature & Humidity
-10 to 60 Degrees Celsius (14F-140F)
Third party testing shows capable of -40C (-40F) cold starts.
0% ~ 93% (relative humidity; non-condensing)
Audio Subsystem
VIA VT1617A 6 channel AC97 Codec
Full Duplex 3D Stereo Sound
Software AC '97 Audio CODEC
3 Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
VGA & Video
Onboard Video, with full Motion Video Acceleration, Hardware MPEG2
Motion Playback at 30 fps.
Integrated VIA Unichrome AGP graphics
MPEG-2 and MPEG-4 Decoding Accelerator
Standard 15 Pin CRT Monitor Connector up to 1280x1024x24
S-Video & Composite Video Output Connectors (NTSC/PAL)
Input & Output Ports
(1) RJ-45 LAN port
(1) PS2 mouse port
(1) PS2 keyboard port
(1) Serial port (external)
(1) Serial port (internal)
(2) USB 2.0 ports (external)
(3) USB 2.0 ports (internal)
(1) D-Sub 15 VGA port
(1) RCA composite video port
(1) S-Video port
(1) 1394 Firewire port
(3) Audio jacks: line-out, line-in and mic-in (Smart 5.1 Support)
(1) Molex wiring harness connector with power, ground, ignition hot.
LAN
VIA VT6103CL 10/100 Base-T Ethernet
Operating System & Software
Windows XP Pro OS Pre-Loaded
Digital Dash Car PC Software Front-End
CPU
VIA C7 1.5ghz NanoBGA embedded processor
133mhz FSB
Low power consumption (<15W)
RAM
1024mb (1gb) DDR2 533 RAM
Hard Disk
80gb 2.5" Mobile Laptop Drive
5400rpm rotational speed
Mounted on rubber-shock absorbing dampers
High non-operating shock tolerance by load / unload technology
FDB (Fluid Dynamic Bearing) motor for ultra silent operation
Vibration Operating 9.8m/s2 { 1.0G } (5 to 500Hz)
Shock Operating 1,960m/s2 { 200G } 2ms
Optical Drive
Optional Slim Slot Loading External Firewire DVD/RW+ Combo
System Board
VIA CN700 North Bridge Chipset
VIA VT8237RP South Bridge
Embedded Motherboard
Award 4 MB Flash ROM
240pin DD2 DIMM socket w/locking mechanism
Wake-on-LAN
Keyboard Power-on
Timer Power-on
System power management
Power failure recovery
Power Supply
Intelligent Vehicle Power Supply
ATX, 6-24V wide input range
Intelligent shutdown controller, powers on and off with ignition.
ON/OFF motherboard control
Survives vehicle engine cranks
Battery deep discharge prevention
High efficiency, 90 watts output
Works with 12V / 24V car batteries
"Anti-Thump" Amplifier remote control
10A automotive fuse (mini-blade)
Expansion Slots
(1) PCMCIA Slot - CardBus Type I & Type II
(1) Compact Flash Slot
Ford F-250 Crew Cab Super Duty. Looking to install a full audio/video system integrated with a mobile computer.
