The MP3car.com Store
Thread Tools Display Modes
Old 09-24-2007, 03:41 PM   #1
My Photos: (0)
Getting distortion at higher volumes
I'm just curious if this is normal: When I turn up my volume on my computer I get a lot of distortion when there is a lot of bass in the song. It sounds alright, but not great when the bass is minimal in the song. Here is my current setup, I know it is by no means good but it is decent for the time being.
Kenwood KAC-8403 4 channel amp
http://www.crutchfield.com/S-SW5Klrb...3&i=113KAC8403
Kenwood KFC-1661S 6-1/2"/6-3/4" 3-way Speakers(Front Doors)
http://www.crutchfield.com/S-SW5Klrb...S&i=113KFC1661
Infinity Reference 3012cf 3-1/2" 2-way Speakers(Rear Doors)
http://www.crutchfield.com/S-SW5Klrb...2cf&i=1083012C
It kind of sounds like they are almost rattling but I installed them with dynamat to prevent just that. I've been trying to mess with the settings on centrafuse to help aleviate but it hasn't been working to well.
I had the speakers installed with the factory head unit of my 2001 chevy silverado and they sounded fine. So is there anything I can check that may be the cause, or is it just that the equipment is not too good. Thanks.
Ryan711 is offline   Reply With Quote
Sponsored Links
Old 09-24-2007, 11:27 PM   #2
boomintrac's CarPC Specs
boomintrac's Avatar
Vehicle: A little white wagon
My Photos: (0)
on the amp where is the x-overs set? where are the gains set. My guess would be impropper settings.
Gm started doing some stuff that started in about 2000 that alters the frequency curve as the volume is increased in their factory radios, in short the louder you crank it the more bass is cut. That could be why you were happy with it in the silverado.
Aron
My Worklog
Asus P5PE-VM Board
Intel Celeron D 356 Processor
512 DDR 400 Ram
Seagate SATA 2.5" 160GB HDD
D-Link DWL-510 Wireless PCI card
2 M2-ATX power supplies
T-view T 800-TS
BU-353 W/IG4
Linksys HGA7S high gain antenna
Verizon USB720
boomintrac is offline   Reply With Quote
Old 09-25-2007, 12:20 AM   #3
My Photos: (0)
I think i've found out the problem, I didn't install the bass blockers on the rear speakers because I didn't know what they were for and the instuctions didn't say anything about them. My amp has a high pass filter so i'm just going to set that at 75 hertz which is what the lowest frequency that the rear speakers can handle. I think that what was causing the massive distortion on the bass.
I'll probably end up getting a sub because the mids and highs on the speakers I got are decent but the bass sucks bad.
Old 09-25-2007, 10:19 AM   #4
Vehicle: 1991 Chevy Suburban 1500
My Photos: (0)
when you are dealing with amps and mixers, you want to keep your input signal as "hot" as possible, however, there is such a thing as too hot of a signal. If the signal coming from the computer to the amp is higher than what the amp can support, it will start clipping and possibly even shutting down the amp (protection). So, I would try to turn the gain up on the amp a tad, and turn it down on the computer. either that or leave the computer alone, and turn the gain down on the amp, but this may not work either. Try lowering the volume on the computer, and if it isn't loud enough, turn the amp up slowly until you start to hear distortion, then turn it down a hair so it doesn't distort. Hopefully this will help.
Crawdaddy is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Issue with Speaker distortion Rosadocc General Hardware Discussion 0 11-14-2006 12:49 PM
Can distortion of a speaker damage/kill an amplifier? nobb Car Audio 8 11-13-2006 10:38 PM
Higher power Wifi = Longer Range? AcuraTLFan Wireless Communications 6 08-17-2006 05:56 PM
Amps Protecting at high volumes kdunn926 Car Audio 1 08-30-2005 09:14 PM
buzz/hum from Lilliput? higher pitch with higher RPMs... chris in nh Car Audio 13 07-25-2004 11:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
