Old 09-28-2007, 12:43 AM   #1
Alpinity is an unknown quantity at this point
Subwoofer wiring help
I have a Power Acoustik 12" FUBR Sub. The impedance is dual 2-ohm. I was wondering about a few things. First, what type of amplifier would suit this configuration best, like mono 1-ohm stable or what? Also, does powering 2 subs with a mono amp make the amp run hotter than it usually would? Any help would be good!!!
Alpinity is offline   Reply With Quote
Old 09-28-2007, 11:55 PM   #2
goguygo is an unknown quantity at this point
There are 1 ohm mono stable amps, but they are few, and fewer still can run that low a load consistantly without breakdown. If you are looking to use that subwoofer I recommend running it in series for a 4 ohm load instead of parallel for a 1 ohm load. There are many fine amplifiers to choose from that will run at 4 ohm mono all day long.
As far as multiple subs, the final impedence load is the key here as well, not the number of speakers the amplifier is driving.
goguygo is offline   Reply With Quote
embarrassed to ask: subwoofer wiring? telekineticfool Car Audio 15 09-14-2009 04:32 PM
dual vioce coil sub/amp wiring hotponyshoes Car Audio 32 12-24-2007 01:20 AM
Wiring Subwoofer breezeer Car Audio 13 05-11-2007 08:12 PM
Is my subwoofer amp pooched? WoLLy Car Audio 13 04-01-2006 11:16 PM
$20 Orion subwoofer box with 2 Orion Cobalt 10' inch SUBWOOFER SPEAKERS and JBL AMP nycjuni Classified Archive 4 09-19-2005 07:41 AM
