Old 09-28-2007, 02:26 AM   #1
rev1richie is an unknown quantity at this point
Output from Carpc to Amp
Hi
I have got a Dell SX260 setup and a small amp to power the speakers, i would like to know if i can take the On Board sound output (from the Greenplug) into my amp or does it need to be a line out from a usb sound card?
rev1richie is offline   Reply With Quote
Old 09-28-2007, 02:38 AM   #2
S4Per's Avatar
S4Per is on a distinguished road
You likely CAN use the onboard output, given you have a cable that has the right connectors on each end. The question is around the quality of that output and if a USB sound card would provide higher quality (likely it will).
S4Per is offline   Reply With Quote
Old 09-28-2007, 02:41 AM   #3
thanks
found this FAQ as well http://www.mp3car.com/vbulletin/advf...ew&advfaqid=29 (couldn't find it before, blind as a bat) which helps,
I have got a cable which is 3.5 mini jack to 2 x RCA, one more question, if i did use the onboard, would i take it direct to the speakers or to my amp then the speakers?
Old 09-28-2007, 03:16 AM   #4
FC3S's Avatar
FC3S can only hope to improve
you would go from onboard -> amp -> speakers
onboard wouldnt have enough power to drive speakers
FC3S is offline   Reply With Quote
Old 09-28-2007, 11:56 AM   #5
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Don't be surprised if you're not happy with the quality of the sound coming from the onboard audio....if you aren't happy with it then move to an upgraded sound card (PCI/USB/Firewire/etc.)
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Amp behavior. enitalp Car Audio 1 05-01-2006 09:06 AM
Powering carpc and amp bjfrank Car Audio 6 04-11-2006 02:32 AM
CarPC directly into Monsoon Amp, do I really need the Head Unit? ericthebikeman Car Audio 20 10-31-2004 10:53 PM
amp for EPia-10000M audio output loscooby General Hardware Discussion 0 02-08-2004 04:49 PM
