Car PC -> EQ -> Factory Amp
I've searched the forums but couldn't find this scenario...
I have a honda element with a built in amp. I am wondering if it would be possible to go this route when installing my CarP00Ter...
Can i run the audio out from my CarPuter to an EQ to split up the channels, and then run the output from the EQ to the factory harness. The factory harness will then run through the factory amp and output through the speakers.... at least that's my theory....
(CARPUTER -> EQ -> FACTORY HARNESS -> FACTORY AMP -> SPEAKERS)
This will eliminate the need for a head unit and also the need to replace the factory amp + wiring which is a ****** to access. Can someone with some expertise advise if this solution is doable and/or a even worthwhile?
Reason: spelling error.
