Quote: Originally Posted by
1bacavy
i just bought 2 12" Alpine Type R subs...they are dual 2 ohm...i have a kenwood 1800 watt amp and will be pushing 900 watts at 2 ohms to each sub...which was sounds better when mounting, the regular way or reverse way?
One thing to note - if they are dual 2-Ohm voice coil subs, then you will be pushing either 1-Ohm or 4-Ohms to each sub - they could be wired to present a 2-Ohm load together, but not each. If your post was a typo, then never mind.
