Old 09-29-2007, 12:43 AM   #1
jacew is on a distinguished road
Which cable do I need?
My headunit has a headphone jack on it, and I'm connecting an mp3 player with the same headphone jack on it. I have a cable that has a headphone male end on both ends and when installed I only get sound out of one channel, but if I retract the cable just a little I can get both channels.
Now...If I take a headphone to RCA adapter cable and use a double female RCA adapter to connect 2 headphone to RCA cable adapters, they work fine.
I just need to know exactly what cable I need to connect these 2 devices via the headphone jacks to get both channels.
Thanks.
jacew is offline   Reply With Quote
Old 09-29-2007, 07:21 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
A stereo line in cable.
It will have the 1/8" headphone jack on both ends. It sounds as if the cable you have is either mono or damaged.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 10-01-2007, 01:37 PM   #3
brandname2007 is an unknown quantity at this point
Yeah, it sounds like you need a stereo cable. As dumb as it sounds, most portable devices come with a single channel mono cable.
brandname2007 is offline   Reply With Quote
Old 10-01-2007, 01:40 PM   #4
A good way to identify which one you have: If the plug has two little "black rings" around it, it is stereo, if it only has one, then it is mono.
Messed up VGA/USB cable carfreak01 LCD/Display 12 08-19-2005 07:08 PM
VGA Cable Question (Pinouts) Bugbyte LCD/Display 2 07-26-2005 09:54 AM
FS: Modded Xenarc 20-pin Cable - 6 foot hd54321 Classified Archive 3 05-27-2005 03:54 PM
Need help on extending the Lilliput cable nthai LCD/Display 5 04-27-2005 01:59 PM
FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP! 1300mer Classified Archive 9 08-13-2004 02:47 PM
