Old 09-29-2007, 09:28 PM   #1
hondaacord is an unknown quantity at this point
Velcro for Sub Enclosure
Hi, I have a sub in a sealed enclosure in the trunk of my 95' honda accord, and I don't have the enclosure secured yet. People have recommended I use velcro, but I have no idea where to get it. Does anyone know where to get this type of velcro?
Thanks in advance.
hondaacord is offline   Reply With Quote
Old 09-29-2007, 10:40 PM   #2
lbridges is an unknown quantity at this point
You can get 2" wide strips of Velcro at places like Home Depot, Lowes, Ace Hardware, but honestly I wouldn't recommend it. I have some serious doubts about it's ability to hold a woofer in place during sudden stops, etc. I have used it to secure things like a graphic equalizer to a carpeted panel, but then that only weighs about a pound.
lbridges is offline   Reply With Quote
Old 09-30-2007, 06:43 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
I'd recommend something more than velcro.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-30-2007, 08:39 AM   #4
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Velcro isn't going to secure a sub enclosure, not in the least.
L brackets or the like would be your best bet.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 10-01-2007, 02:00 AM   #5
Mr Beta is on a distinguished road
Even if it's custom molded to the corner of your trunk? If that makes any sense at all.
Mr Beta is offline   Reply With Quote
Old 10-01-2007, 08:50 AM   #6
Do you want to rish that sub box coming loose at all?
Do what you want, but I suggest some L-brackets to secure it in place.
Old 10-01-2007, 09:12 AM   #7
_
Just because it's custom molded to an area doesn't make it any less likely to come loose and fly around in an accident. If it's custom molded then securing it should have been thought about when building the enclosure.
For instance, when we made the sub enclosure for the Gti we made sure we were able to bolt it to the car in 3 places...
It's thinking ahead that gets you out of jams in fabrication like this.
Jan Bennett
Old 10-01-2007, 12:19 PM   #8
bling78 is an unknown quantity at this point
Staples also sells the 2 inch wide velcro in rolls. But I would suggest getting the bungie cord hooks they secure it tightly. But I mean if you dont want the cords visible then the velcro seams like an decent idea. They sell those at most auto parts stores or other places. Usually the weight of the box is enough to hold the box from moving much at all and the velcro will just reinforce it from sliding.
bling78 is offline   Reply With Quote
Old 10-01-2007, 01:26 PM   #9
_
velcro and bungie straps are NOT suitable methods to tie down or secure a sub enclosure.
Jan Bennett
Old 10-01-2007, 04:41 PM   #10
Megalomaniac's Avatar
Megalomaniac is on a distinguished road
Use L-Brackets just as cheap, except more effective
Megalomaniac is offline   Reply With Quote
Old 10-02-2007, 07:09 AM   #11
I wouldn't risk it either. I've just heard of people that don't anchor their custom boxes because they're a snug fit.
Old 10-02-2007, 04:03 PM   #12
BiG K is on a distinguished road
You can use velcro........you would be surprised how strong it is!
Just as long as you cover the entire sub floor and wherever else it comes into contact with the carpet, you will be fine!
BiG K is offline   Reply With Quote
Old 10-02-2007, 04:09 PM   #13
_
Velcro would not be fine....
Jan Bennett
Old 10-02-2007, 06:14 PM   #14
You will not be fine!
i dont care how strong the velcro is it will not be as effective then screwing it down. safety should be priority number 1 when installing anything.
Old 10-02-2007, 07:06 PM   #15
OldOneEye is an unknown quantity at this point
Did an install in my best friends 1999 Escort hatchback. Hit a pole, the sub box broke through the back seat (fold down seat, steal back.. similar to Jan's GTI). The power wire on the amp kept the box from scrambling his brain.
Not only that, if you don't want a thief to take it, you want to bolt it down.
Juan
OldOneEye is offline   Reply With Quote
Fiberglass and MDF sub enclosure walkthrough monkeyracer Fabrication 28 05-19-2008 03:55 PM
Need Help fabricating enclosure. MastaShake Fabrication 10 08-22-2007 04:23 AM
Need help with camera enclosure Gayden Input Devices 0 08-31-2006 06:30 PM
USB 2.5 Drive Enclosure blkwrx General Hardware Discussion 4 06-27-2006 11:55 AM
slim optical enclosure with internal battery zPilott General Hardware Discussion 0 08-23-2004 07:29 PM
