Old 10-01-2007, 12:39 PM   #1
DAMBRO24's Avatar
DAMBRO24 is on a distinguished road
Creative Usb Works Great!!!
hello I have a creative usb audio apatoor that makes m car sound about 3000x better. very goos clear sound unlike the soundcard in the jetway 1.5 I have. (its sound like sheet) anyway this setup is perfect for me and I love it but the one problem is I get no popping from the stock sound card , but when the creative usb soundcard is attached it has this popping problem , how can i ground the sound car and do you think it will work?
DAMBRO24 is offline   Reply With Quote
Old 10-01-2007, 01:04 PM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
constant popping while playing or just at startup?
Search for "turn-on pop" if it's just at startup. There are multiple ways to get rid of it. Are you running it to an external amp or to a headunit?
System always under construction
durwood is offline   Reply With Quote
Old 10-01-2007, 01:12 PM   #3
DAMBRO24's Avatar
not start up
its not on start up at all
thank you though. It is the entire time the songs are playing. they re very scattered pops the entire time of play. very annoying.
Old 10-01-2007, 04:13 PM   #4
mscappa is an unknown quantity at this point
try putting the creative device on its own USB port, not through the a hub. External soundcards are USB-bandwidth hungry and don't like to share. That is what the popping is from. Sound like rice crispies, right?
mscappa is offline   Reply With Quote
Old 10-01-2007, 05:13 PM   #5
DAMBRO24's Avatar
help
i d not have it runnin off a hub. but i will try to switch usb ports and see what that does. any other ideas
Old 10-01-2007, 10:16 PM   #6
Nola111's Avatar
Nola111 is an unknown quantity at this point
What card is this?? Apatoor? Never heard of it. Is that the correct spelling? I thought I knew about most Creative cards.
Nola111 is offline   Reply With Quote
Old 10-02-2007, 02:37 AM   #7
kegger is an unknown quantity at this point
its the firmware versions for the bios, try updating with the latest one
kegger is offline   Reply With Quote
Old 10-02-2007, 04:21 AM   #8
BiG K is on a distinguished road
wrap the creative USB soundcard up in foil. If its interference, it'll take care of it!
BiG K is offline   Reply With Quote
Old 10-02-2007, 04:39 AM   #9
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
...Then boom when the foil shorts it out
Unless of course the Apatoor in question is already in its own protective case
ShawJohn is offline   Reply With Quote
Old 10-02-2007, 01:36 PM   #10
Bimmerstyle's Avatar
Bimmerstyle is on a distinguished road
I have a similar problem with my external extagy I think. At first I thought a small rock had hit the windshield. Does it sound like this? I don't have it very often though. Ones in a couple of days or so. So I don't really mind.
BMW 525tds -Biostar I94GM-I4 -Celeron M44O 1,86GHz, M2-ATX, 1Gb, 320GB -HQCT RDS tuner -Creative Extigy -iBus controller -Lilliput 7" touchscreen -DLS Ultimate A7 amplifier -Focal 130K, 130V, 27V2 speakers
Bezel Worklog-My Install -iDrive F01 RR Skin
Bimmerstyle is offline   Reply With Quote
Old 10-02-2007, 02:20 PM   #11
Car Audio Moderator
durwood's Avatar
Are you sure that it's not your cell phone causing interference?
To the OP-
Have you tired re-installing your drivers? What's the CPU useage like? There could be an IRQ conflict too.
Another thing you could try is to bring your hardware acceleration down a notch on your video card settings.
Old 10-02-2007, 02:24 PM   #12
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
the extigy is externally powered.. you shouldnt have bandwidth issues with it. I just bought an external creative live sound card and it sounds pretty sweet. Its on a hub (internal hub) and has no noise issues what so ever with my 1.3ghz processor.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Sonicxtacy02 is online now   Reply With Quote
Old 10-02-2007, 02:48 PM   #13
No, not sure of that. A little difficult to track down however since it doesn't happen very often. So I have to turn off my cell phone everytime I use the car. Not very convienent...
It's not a "diddirrydiddirrydid" sound if that's what you mean. It just a smal "tack" as if something has hit the windshield.
My thoughts excactly when I bought it. It's pretty old, so not a lot of system requirements, USB 1.1, so no bandwith issues, and externaly powered, so not draining my 5V rail.
But I'm pretty happy with it. It sounds good and the "tack" sound only happens very little so I don't really bother about it. Just posted this to let people know there were others with problems on this subject.
Old 10-02-2007, 03:53 PM   #14
DAMBRO24's Avatar
Creative Xmod
is the opne I have
Old 10-02-2007, 03:54 PM   #15
DAMBRO24's Avatar
maybe I should try grounding my case itself and see it that takes . anyone . strill popping n
Great tiny USB hub meisner General Hardware Discussion 1 08-12-2007 10:20 PM
PCS Power Vision works via USB, but not full speed on BT LiquidKernel Wireless Communications 4 02-18-2007 09:45 PM
Hibernation with Creative SB USB teo256 Road Runner 35 09-18-2006 06:57 AM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
What USB BUS POWERED soundcard works with mediacar? jusatry MediaCar 3 06-01-2004 11:37 PM
