Old 10-04-2007, 08:27 PM   #1
jscoobya is an unknown quantity at this point
1989 Town Car issues
Hello
Im new to the site. I have a few questions about moding my 1989 Town Car. I recently purchased a Dual XDM6820, a pair of 6 1/2" 200 watts three way Roadmaster speakers, a pair of 6"x9" 400 watts three way Road master speakers. When I went to install it all i noticed that my car was equiped with "Permium sound" so could not use half the wiring harness kit that bought. The speaker wiring harness was diffrent because it hooked up to a factory amp in the back, I could not figure out how to wire the new head with it so i ran all new 18G speaker wire. It all sounds good except when i turn it up to about 35-40 with alot of bass, I get this anoying high pitched sound that kind of sounds like a guitar wire vibrating, the sound is parallel to the pounding of the bass. I was wondering if anybody knew what could be cause'n it.
Now for my next question, I wanted to purchase 2 amps to place in the trunk along with some subs. But I cant figure out how to wire the Amps. I dont have the money to purchase the amps/subs atm since i recked my wives car(06 uplander). But i want to get the wiring done. I have an RCA cable that will conect to the Dual stero via the pre-amp output. my major issue atm is runing the big beefy power cable thru the firewall. How should I go about it? Or should i just run the power cable under the car, near the frame bars, then into the trunk?
Thank you for your time.
jscoobya is offline   Reply With Quote
Old 10-05-2007, 09:41 AM   #2
envisionelec is an unknown quantity at this point
Quote: Originally Posted by jscoobya View Post
Hello
Yes, the 6x9s are picking up the vibrations of the subwoofers, sending a voltage into the sub amp's "speaker level input" (you didn't mention, but that's how it happens) via the speaker wires and coming back out the subs. It's basic feedback. You will need to either turn the sub amp down or use RCA cables into the sub amp.
envisionelec is offline   Reply With Quote
Old 10-05-2007, 07:25 PM   #3
I dont have an amp or a sub in the vhicle atm, the sound is coming from the 6"x9"
What's your dream car? Aaron Cake Off Topic 172 10-02-2007 08:34 AM
Car PC & Bose/Philips CCR800 Aux input Gamer64 Car Audio 1 01-25-2007 04:13 PM
I think my CarPC is emotionally attached to me. Freezes when I get out of my car! 2k1Toaster General Hardware Discussion 19 12-16-2006 12:27 AM
Attention Newbies! A FAQ to the FAQs Bugbyte The FAQ Emporium 4 06-16-2006 12:17 AM
