Old 10-05-2007, 04:19 PM   #1
WuNgUn's Avatar
WuNgUn is on a distinguished road
Remote "ON" for amp's...use the PC?
How is everyone remote turning their amps on in there cars when running a carPC?
Do you just tap into the 5V lead on the PC's power supply?
WuNgUn is offline   Reply With Quote
Old 10-05-2007, 04:33 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
What amp do you have that takes 5v?
And most people use the built in anti-thump (turns on after sound drivers are initialized) on their DC-DC PSU.
Old 10-05-2007, 04:34 PM   #3
Felix509's Avatar
Felix509 is an unknown quantity at this point
You need 12vdc to turn on the amps, not 5vdc.. How are you triggering your PC power supply?? What power supply are you using, My OPUS power supply has 12v remote turn on outputs just for amps/processors/etc.
My truck has a spare cigarette lighter outlet in the back that was energized when the key was on.. I just cut those wires as i never use that outlet, and I use that for the whole turn on for everything from the computer to the amps. It only requires a few milliamps i believe..
Ours is the age that is proud of machines that think and suspicious of men who try to.
___________________________________
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
Rainbow Profi CS365 & Profi Vanadium 12"
Felix509 is offline   Reply With Quote
Old 10-05-2007, 05:14 PM   #4
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
Most all DC-DC PSUs have the remote turn on feature built in already, no need to reinvent the wheel...
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Pocket PC Remote for RoadRunner ? CdRsKuLL Road Runner 58 05-26-2008 01:56 AM
How to power up my pc via pre define remote power button pasan Power Supplies 0 04-01-2007 04:09 PM
X-10 Pc Remote Osiris Girder 2 03-18-2005 09:41 PM
Wiring remote start switch for cappuccino pc wkolodny General Hardware Discussion 3 04-25-2004 03:32 PM
