Old 10-07-2007, 10:39 PM   #1
blackdouglas76 is an unknown quantity at this point
Emergency Answer Needed !!!
Ok, not a real big emergency, but considering how impatient I am, its close.
Anyway, I want to hook up my subs tomorrow, but have never done any in a series.
I know that I must connect a wire from the + on amp to + on speaker. Then, - on that speaker to + on second speaker. Last, - on speaker to - on amp.
The problem I am having is that I don't know if you have to make the + and -connection on the same channel of the Amp, EITHER (L) or (R), or if you split the connection on the Amp and use BOTH (R) and (L) channels.
This website shows using only one channel of the amp. Is this right? Do I have to choose the (R) channel if so? Could I use the (L) side or do I use both the (R) and (L) side?
http://www.caraudiobook.com/car_audi...amplifiers.htm
Thanks to anyone with a quick and correct response,
JIM
blackdouglas76 is offline   Reply With Quote
Old 10-08-2007, 10:51 AM   #2
davidingermany is an unknown quantity at this point
It all depends on the amp and speakers. Why are you doing this in the 1st place? there will be no benefit over running it in stereo with running them in a series. If they are 2 ohm subs and the amp is 4 ohm mono capable then there is a reason.. the amp will act if it has a 4 ohm mono load but 2 4 ohm subs in a series will be 8 ohm mono this config has no benefits over 4 ohm stereo .
davidingermany is offline   Reply With Quote
Old 10-08-2007, 12:06 PM   #3
JKrepps is an unknown quantity at this point
An echo for Davidingermany, to my knowledge it depends entirely on the amp, and the manual or website should tell you.
If you post the details on amp and subs you would get a better answer, I suspect.
JKrepps is offline   Reply With Quote
Old 10-08-2007, 01:59 PM   #4
AJ3000's Avatar
AJ3000 is an unknown quantity at this point
need more info on speakers, but i agree with the above
East Coast Audio UK
Daewoo Lanos "Woo of Doom" Show Car
Fabrication 4%
Bodywork 0%
carputer 1%
Finish Line - not even in sight!
TOTAL SPENT SO FAR £250
AJ3000 is offline   Reply With Quote
Needed, Last few Norwegian translations needed veetid Centrafuse 1 06-13-2007 11:55 AM
Forum Etiquette Enforcer Newbie 5 01-09-2006 06:58 PM
Will someone be willing to answer a few questions about the Vietnam War for an essay? guitar333 Off Topic 6 05-25-2005 12:53 PM
My project for the day - advice needed ddt General MP3Car Discussion 2 12-02-2002 08:51 AM
12.5 CTX Pano View AC adaptor needed! outragis LCD/Display 1 07-29-2002 12:55 AM
