Old 10-13-2007, 04:02 AM   #1
chee is an unknown quantity at this point
Help on car sub pls. =)
Hi.
I'm looking for a sub that's not to pricey and sounds good. I listen to a lot of incubus, dmb, jeff buckley, muse and stuff (even old school stuff like pantera, pearl jam, stp, etc.) Anyways, with my stock system, I don't feel the kick of the drum and the groove of the bassline. Any suggestions?
Also, is the alpine type r sub good?
Thanks very much for the help.
cheeno
chee is offline   Reply With Quote
Old 10-13-2007, 12:04 PM   #2
alienmanfc6's Avatar
alienmanfc6 is an unknown quantity at this point
What kinda price range we talking here. Cuz i would highly recomend audobahn, but they cost alittle more. And based on the kinda music you listen to 10" subs would be way better than 12", 12s will give you to much thump while the 10s will give you much cleaner sound. and avoid sony xplods, while the price my be cheap they are not worth
it. like my dad always says 'you get what you pay for'.
hope this helps you
alienmanfc6 is offline   Reply With Quote
Old 10-14-2007, 01:22 AM   #3
speakermakers is an unknown quantity at this point
You want a sub that is efficient in the 35-45 Hz region and that has smooth transient response (group delay) in that region. Transient response is how fast a sub will respond to the program material (music). Transient response is not effected directly by the size of the woofer (that is a myth). It is however effected primarily by the by the resonance magnitude and frequency (EBP) of the woofer used and secondary the design of the enclosure. The skinny of the situation is that for the type of music that you like and the budget restrictions that you have your best option will be a sub along the lines of MTX, or Zapco Iforce, type R or Focal A1 along with a properly designed ported enclosure. I must warn you though in order to achieve the desired results you will have to do a little research and find a shop that can test your sub (do not rely on the manufacturer specs!) and then design an enclosure for you that is based on those obtained parameters. Testing your sub and designing your enclosure should be around $100. That might seem pricy but the results will (if done correctly) more than offset the price of a much more expensive sub. I have been testing subs and designing enclosures for more than 15 years and I can honestly say that a $80 sub in the right enclosure can easily out perform a $1,000 sub in the wrong enclosure every time. If you encounter any one or any shop that wants to rely on the manufacturer specifications for designing an enclosure be ware that you are dealing with ignorance!
speakermakers is offline   Reply With Quote
What's your dream car? Aaron Cake Off Topic 172 10-02-2007 08:34 AM
In a real PC car struggle markland556 Off Topic 10 06-27-2007 12:36 PM
First Car PC Questions - Pretty Long Post Sorry :D [56k death] FiReToY Newbie 9 06-08-2006 06:15 PM
Employee Discounted Cars: Flatout BIG LIE! sdashiki Off Topic 33 10-31-2005 06:53 PM
Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail! hd54321 Power Supplies 1 02-24-2005 01:42 PM
