Old 10-15-2007, 08:04 PM   #1
Snortonnorton is an unknown quantity at this point
how do i balance pc audio to speakers?
I'm using just the pc audio (no amp, just direct to HU)
and I have sound only on side of the car. Balancing the head unit does not help much, it's like the sound is coming from pc to only one channel or whatever.
what should I try to balance it, if possible? i'm running the audio from the intel valley board itx, I did just switch motherboards so maybe i should check the windows audio parameters, then should I choose a specific audio setup for Roard runner config or from winamp?
thanks.
Snortonnorton is offline   Reply With Quote
Old 10-15-2007, 10:29 PM   #2
Dennis5587's Avatar
Dennis5587 is on a distinguished road
Check your 1/8 " to rca adapter and make sure you didn't pick up an mono one, the mono would have the tip part, and a long center part, stereo would have a plastic divider half way through that long center part... good place to start.
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 10-15-2007, 10:43 PM   #3
thanks, can't remember what I got for all the audio card to HU parts,
so I will check on that. I'm pretty happy with the sound quality, just need to balance it.
inline fm modulators with good ground loop isolators work wonders if you don't want to install an amp
thanks a million for the help,
Old 10-20-2007, 08:52 PM   #4
JayD1056 is an unknown quantity at this point
I had a similar problem last week, for some reason the wave balance got pushed 95% of the way to the left side, check the system balance. on both main and wave output.
Jay
JayD1056 is offline   Reply With Quote
Old 06-04-2008, 08:31 PM   #5
you guys were right.
I had a mono 1/8 line from sound card.
what a stupid problem.
but why do they even make a mono line? why not just make stereo lines?
Old 06-04-2008, 08:38 PM   #6
pancit175 is on a distinguished road
So that uninformed consumers are forced to pay twice the cost of a cable when the accidentially purchase the wrong cable. YES/NO?
PROGRESS:
pancit175 is offline   Reply With Quote
PC audio too low Alphared General Hardware Discussion 5 10-04-2008 05:20 PM
How to hook car PC up to stock speakers & subwoofers. jcovercash Car Audio 2 06-14-2007 03:09 PM
Nasty, Nasty PC Audio akwash79 Car Audio 27 05-11-2007 04:37 PM
what is the easiest way for pc to stock audio? Snortonnorton Car Audio 10 03-25-2007 07:48 AM
