Old 10-16-2007, 10:57 PM   #1
gti4dr is an unknown quantity at this point
Connecting Volume Fadder to Zalman External Sound Card
hi guys, just wondering if a volume fadder knob will work correctly with the Zalman external sound card which has 3 outputs, 1 for front speakers, 1 for rear speakers and 1 for sub/centre speakers,
I plan to run a 3.5mm to 2rca into a volume fadder knob, then 2rca out of the fadder knob into my amp that runs my speakers. from the sub/centre output on the zalman card ill run 2.5mm to 2rca connector into my amp that controls the sub.
with this setup, if i turn down the volume, will the sub volume turn down as well or will it alter the ammount of bass running through it.
i can post a diagram if needed.
cheers guys
gti4dr is offline   Reply With Quote
Old 10-17-2007, 01:18 AM   #2
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
i dont think it'll work as you're hoping. can you not control volume through the pc? have you looked into the audiocontrol mvc? you actually need to control the volume of 5-6 chans (outputs) at the same time and the mvc is the only device that i know of that will work.
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 10-17-2007, 02:18 AM   #3
well i can get rid of the fadder idea and run my sound from the usb out to my external sound card, then from the sub/centre out run a connection to the amp powering my sub and from the front input on the card run a connection into my amp powering the front speakers and just use on screen volume and even use the griffen usb volume control.. the one in the store thats on special for $19.00
is this a better idea. that way all the channels will be controlled at the same time? or am i still missing the point???
Old 10-17-2007, 05:09 PM   #4
MySQL Error
scott_fx's Avatar
sounds right to me
M10k
My Car Pc Install
Old 10-17-2007, 07:15 PM   #5
sweet, also centrafuse has on screen eq and presets so that will help
HQCT software development Putput Software & Software Development 177 05-17-2009 01:19 PM
Which external sound card ??? Sibi Car Audio 21 04-22-2008 07:51 PM
Ground loop with an external USB card?? Help! (LONG) vettejock99 Car Audio 18 02-05-2006 11:20 AM
FM sound coming from tuner card not sound card Ascension Newbie 2 07-18-2005 05:24 AM
EQ sound question + volume dank_Army General Hardware Discussion 6 02-16-2004 01:09 PM
