Old 12-04-2007, 01:14 PM   #1
UnknownUser is an unknown quantity at this point
Jetta... Monsoon?
Hey everyone,
Well i have a 2001 jetta wolfsburg edition
This is what i did so far... replaced the origanl head unit with a dubble din kenwood head unit... now i dont plan on getting any new speakers or any subs cause i dont have the money but what i do want to do is buy an amp and install it into my car...
but... i need help on knowing if i have a monsoon amp thing or not... where would it be located in the car? i checked the trunk and didnt see anything, im not sure if its like under some carptening or not... but if its not in their then why did my car come with a reference guide to Monsoon/premium sound system guide?
but the whole main idea of this is i want my sound to sound alot better then it is... just by replacing the head unit it made it sound a ton better, now i want to know if i were to buy an amp could i just hook up the stock speakers?
thanks
UnknownUser is offline   Reply With Quote
Old 12-04-2007, 01:33 PM   #2
pokki is an unknown quantity at this point
Well you'll have to cut the speaker cables to install the aftermarket amp anyway so it's irellevant if you have an aftermarket amp or not since you've already changed to an aftermaket headunit.
pokki is offline   Reply With Quote
Old 12-04-2007, 01:51 PM   #3
All right.
thanks, any suggestions on what kinda amp i should look into? like as of right now i just want something that will amke my speakers alot louder and add some more base with out any subs, but i do plan on getting some subs later on when i get the money so basically i need a good amp for now and have it good for later on when i do buy the subs so i dont have ot buy a whole new amp.
thanks
Old 12-04-2007, 06:45 PM   #4
RyanD is an unknown quantity at this point
CAUTION!!!! adding an amp will not add bass to your system, and if the kenwood unit made everything sound that much better, you do not have a factory amp---you would not notice that much of a difference in sound if you did (the factory amps are speced for the factory HU---meaning that the amp would acutally make the sound of your car almost as bad as before you switched head units) there is nothing that can add bass exept a company called waves car audio, which uses phsyco-acoustics to improve bass response--this is bad in two ways-- 1. prolonged listening will give you headaches, 2. it is pretty pricey, especially just to improve bass
i think it is just a better idea to bear with it now and get a sub later
RyanD is offline   Reply With Quote
Old 12-05-2007, 09:39 AM   #5
Lazyflip's Avatar
Lazyflip is on a distinguished road
If you do have the Monsoon Premium Sound system you cannot run the stock speakers with an aftermarket amp.
02' JETTA 1.8T | WORKLOG ALBUM
Lazyflip is offline   Reply With Quote
Old 12-05-2007, 12:19 PM   #6
but i checked in my trunk and i didnt see an amp.... unless i was looking wrong but im sure i would of seen it.... but then again... i dont know why i have the guide...
would anyone know where i can find a picture of where the amp would be located in the car?
its an 01 wolfsburg jetta
Old 12-05-2007, 12:48 PM   #7
Lazyflip's Avatar
If you have the Monsoon sytem, the amp is located in the trunk. It's bolted to the bottom of the rear deck on the passenger side.
Last edited by Lazyflip; 12-05-2007 at 12:57 PM. Reason: Added picture for reference.
Old 12-05-2007, 10:27 PM   #8
allright... i guess i dont have it..
but still got them reference guides.
FAQ: Connecting your soundcard to a Volkswagen Monsoon Amp kbyrd The FAQ Emporium 88 09-04-2009 12:32 AM
Want to hook up my Sandisk mp3 player to my 2001 Jetta monsoon radio ol_mowgli Newbie 4 10-31-2007 09:34 AM
Help with Mk4 Jetta 2001 Monsoon carlostheassin Newbie 1 02-13-2007 01:37 AM
Sirius FM Adapter to Monsoon Radio 2003 JEtta DJKHK1 General Hardware Discussion 2 02-12-2007 12:40 AM
Monsoon system in VW Jetta. HELP!! SteveT178 Car Audio 12 01-14-2006 12:54 PM
