The MP3car.com Store
Thread Tools Display Modes
Old 12-11-2007, 01:52 AM   #1
My Photos: (0)
Buzz coming from speakers
I just set up an aux input on my car for my laptop. When I'm powering the laptop through the lighter socket via an inverter, I get a hum/buzz sound with the audio. It doesn't happen when the laptop is running off its own battery. Is this due to the inverter it self, or the power coming out of the lighter socket? Basically will I resolve this problem by getting a standard car adapter for the laptop? Also, I was told if I put a suppressor in it will solve this, is that true?
Help please.
Champak is offline   Reply With Quote
Sponsored Links
Old 12-11-2007, 02:11 AM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
if by "supressor" you mean ground loop isolator, it will band-aid it probably. You will loose audio quality, I guarentee it 100%.
An inverter is inheritantly noisy and inefficient. That is why serious people do not use them (excluding true sine wave inverters). Also the cigarette lighter is not powerful enough to power a computer. You are opening yourself into overloading the puny wires and potentially a fire hazard.
If you get a DC-DC regulator like the p1900, then run a wire from the battery, you should be set.
Old 12-11-2007, 06:59 AM   #3
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Moved to Car Audio.
You should check this FAQ: http://www.mp3car.com/vbulletin/advf...iew&advfaqid=8
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Why not Home PC speakers for the car? RedGTiVR6 The FAQ Emporium 22 03-05-2008 03:35 PM
6 speakers in 4 inputs? k-drive Car Audio 7 07-18-2006 01:23 PM
So I have decided to change out my factory speakers for something a little better. lawrence Car Audio 12 10-28-2004 06:44 PM
Low volume coming from speakers. nappyjim General MP3Car Discussion 4 10-12-2004 07:19 PM
Noise coming through speakers - Help Needed tbird2340 Car Audio 39 09-27-2004 03:31 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
