The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 12-12-2007, 02:06 AM   #1
My Photos: (0)
USB isolation
Hi,
Okay guys, i got a good one for you, first of all my setup: compaq laptop, powered by inverter, sound by onboard sound card to wired FM modulator(sound quality is EXCELLENT).
everything was going fine till i dicided what the heck, im gonna buy a touchscreen, so i wire the whole thing up and now kaboom, when i plug un the touch screen cables (USB &/or VGA) i get alternator whine (changes w/ revs, yet voltage stays constant), its less pronounced when i have music on full blast but i get tired of reaching for my headunits volume dial under the screen.....is there anyway to isolate these lines????(ps problem is less significant if i unplug one of the two but still present and rerouting was without avail)
thanks
dan
trueppp is offline   Reply With Quote
Sponsored Links
Old 12-12-2007, 08:20 AM   #2
Felix509's CarPC Specs
Felix509's Avatar
Vehicle: 1999 Landcruiser
My Photos: (52)
A few things to check:
Is your Touch screen powered form the cig lighter outlet? May need to power and ground from same place as computer is.
Is your USB cable running alongside power cables? If so the 12V may leak into it.
May need a higher quality USB cable with better shielding..
Just to test, with the car running where you can hear the Alt whine, move the USB cable around to see if the Whine goes away/gets louder. May just need to relocate this cable..
Ours is the age that is proud of machines that think and suspicious of men who try to.
___________________________________
Current SYSTEM
AMD64X2 2.5
Xenarc
ZAPCO DSP-6
ARCAUDIO SE Amps
Rainbow Profi CS365 & Profi Vanadium 12"
Felix509 is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Mini-ITX boards RedGTiVR6 General Hardware Discussion 89 08-27-2008 03:05 PM
Newbie build-up: Ampie CarPC EEEEeeee36 Newbie 56 03-28-2008 09:03 PM
CarPC USB Power Supply Question HiJackZX1 General Hardware Discussion 4 08-08-2007 01:42 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 02:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
Sponsored Links
Ad Management by RedTyger
