The MP3car.com Store
Thread Tools Display Modes
Old 12-17-2007, 07:18 PM   #1
stonestatue's Avatar
Vehicle: 93/Chevy/G20
My Photos: (0)
HQCT vs MOBO sound input.
I intend to get a HQCT unit for the purpose of integrating AM/FM radio into a complete self contained 1.5 DIN unit. Check it out here:
http://store.mp3car.com/HQCT_High_Qu..._p/com-009.htm
It states the following:
"Compact module that uses standard computer connections (Internal motherboard USB pin header, Molex power connector, CD-Rom audio connector) for integration in existing housing of the computer."
The part in bold is what I have a question about. I have read in searching other threads about this topic that it can handle the audio for the motherboard. I am not exactly sure what this means. I know that people that go with headless units (fully integrated into DIN) use the motherboard's 5.1, 6.1, or 7.1 audio feature to connect to an AMP which routes the signal to the speakers. If it helps, I am also planning on putting one of these in the unit:
http://www.41hz.com/main.aspx?pageID=130
So with the HQCT unit and the 41hz Amp9 unit, what would I do with the CD-ROM audio connector of the HQCT?
Self proclaimed environmentalist.
stonestatue is offline   Reply With Quote
Sponsored Links
Old 12-18-2007, 01:34 PM   #2
Bildonia's CarPC Specs
Bildonia's Avatar
Vehicle: 96 Pontiac Sunfire
My Photos: (0)
CD-Rom audio connector was typically a cable that ran from the cd rom drive to the sound card in a computer. This cable is now obsolete since audio travels through the IDE or SATA cable to the motherboard now instead.
In this application, it looks like the USB connection on controls it, and the audio connector will need to be plugged directly into the motherboard to get audio from the tuner
1st CarPC
Plans --> >>>>>>>>><
Parts --> >>>>>>>><<
Install -> <<<<<<<<<<
Bildonia is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
HQCT Module (new thread following HU RDS/RDBS) racemier Hardware Development 1229 06-30-2008 05:37 PM
HQCT Control/Media Manager aeroanderz DigitalMods (Scripts / API) 6 10-10-2007 08:14 AM
FS: Ebay - Ford Aux Sound Input funboy Classified Archive 0 03-19-2006 03:43 PM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 04:04 PM
Via M mobo with FM Modulator Sound Quality swingpoha Car Audio 8 08-02-2004 02:29 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
