12-31-2007, 10:08 PM
#1
remote turn on for amps
okay here is the main question i have at this point, right now i have a pioneer avic-n2 that i am going to sell, when i do im going to put in an lcd and my compaq laptop, now i know how to hook up the rca cables but how do i connect the remote turn on for the amps? The wire from the headunit that tells the amps to turn on. Is there another wire i can use or maybe something off the gm harness that i wont be using?
12-31-2007, 11:07 PM
#2
You can run a relay off whatever will be powering the computer
12-31-2007, 11:18 PM
#3
well its a laptop so im going to be using a belkin auto/air to power it, but i am going to use an m2 atx to power my xbox, i can run the remote wire off that?
12-31-2007, 11:47 PM
#4
Pins J6 on M2-ATX, see the manual for details.
Carputer Project Status:
0% - Mobo died on 2/17/08
Check out the worklog for my '01 Pathfinder.
01-01-2008, 12:20 AM
#5
See post above, but also whatever will be triggering the auto/air plug to go hot could also trigger the amp.
01-01-2008, 02:46 AM
#6
any keyed 12v source will turn the amp on. find something that is controlled by the key and tap into it.
01-07-2008, 04:33 PM
#7
okay so i got my m2-atx today and i am looking it at, the manual says that the left pin is RMT and right is the ground. So i have to ground the pin itself?
03-22-2008, 11:12 AM
#8
im wondering the same thing. any help?
95 Mustang 5.0
Custom Case, VIA m10000, 512 MB, 80gig, M2-ATX, Slot Load DVD, 7" LCD Touchscreen
80% done
03-22-2008, 11:01 PM
#9
well i couldnt get it to work either way, so i used the 12v wire from the radio to power it, i installed a switch so that i can turn the amps on/off so i wait until the computer has loaded before i turn it on
03-24-2008, 12:07 AM
#10
I'm turning my amp on using the j6 jumper on a m2-atx and I don't have the ground pin hooked up to anything. The RMT pin runs straight to the turn on lead on the amp. It works great; The m2-atx delays turning on the amp for a couple seconds so you don't get any amplifier pop when it turns on.
03-24-2008, 06:16 PM
#11
thanks for the help
95 Mustang 5.0
80% done
04-24-2008, 09:23 AM
#12
using a molex to remote the amp
hi,
can i use a 12v from a molex connector to send the signal to the amp?
i have a faulty m2-atx with a fried J6 transistor, then im thinking to use this as a regular psu. i'd like to confirm if when the mobo is turned off the 12v rail of the molex connector is energized or not?
thanks,
| Thread Tools |
| Display Modes |
Linear Mode
