Old 01-02-2008, 12:55 PM   #1
amemo06's Avatar
amemo06 is an unknown quantity at this point
USB sound card output level
Hi, I've not found a clear information in forum. Sorry.
I have a 3 amplifier installation : front stereo / rear stereo / sub
My infill G4 don't have line outs to connect to the amps.
So I plan to buy a USB 5.1 or 4.1 sound card. eg: Turtle Beach Roadie...
The installer(pro but not for carputer) warn me about the output level of the soundcard to attack the amplifiers.
He would like something around 2v per channel.
As far as I understood (FAQ, ...), the SB audigy 2NX was claiming 2vrms !
The Turtle Beach and most of the other USB sound cards says nothing
The question is :
- Is there something basic I did not understood?
- Does the Turtle Beach powerfull enough.
- Which other USB ones should I consider ?
Thanks in advance
Alain
For info the current materiel is:
1 Infill G4
1 audison VR 404 XR (Front channel)
1 audison LR 435 (Rear Channel)
1 sony XM 5520 (Sub)
Also I found the documentation of the Audison (not the Sony one)
The VR404XR has an input sensitivity of 0,15 V ÷ 1,5 VRMS
The LR435 0,15 V - 1,5 V
The Sony I don't know
amemo06 is offline   Reply With Quote
Old 01-03-2008, 01:23 AM   #2
customaudioman's Avatar
customaudioman is on a distinguished road
The question is :
Thanks in advance
Alain
1 Infill G4
I would go with the SB audigy 2NX. It has 2v rms signal. I use the audigy 2nx for my setup. I have the sound card 2 ft away from my carputer which is mounted in the trunk area. Your systems is in the front of the car, which your going to have to run rca back to the amp.It would help if maybe if you got voltage booster to get the volt to at least 4-5volts since it further distance from front to back. If it was mounted in the trunk, can go from carputer right into the amps, less distance to travel for signal loss.It will still sound good w/ just the 2v to the back, but you would get a little better sound with card+ boosters.
customaudioman is offline   Reply With Quote
Old 01-03-2008, 04:44 AM   #3
amemo06's Avatar
Hi
Thanks for the info. I was thinking the same initially.
The Audigy 2NX was looking very good, unfortunately this product is not available anymore and I did not find any who sell it.
Do you have more informations about the booster.
Also did any one has idea about a :
sound card => signal booster => my amps
in comparison with
Infill internal amp => High level to low converter => my amps
Old 01-03-2008, 01:12 PM   #4
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
The mp3car store now carries the esi-pro gigaport. Might be another option for you. I'm not sure what brands are easier for you to find in Europe.
System always under construction
durwood is offline   Reply With Quote
Old 01-03-2008, 04:07 PM   #5
eliaz is an unknown quantity at this point
You could also use a high to low level signal adapter. I use that with my Infill G4 to convert the signal so I can send it to my amp. I am running the high output channels to that converter for my front speakers, then into my amp. I am running my rear speakers straight into the Infill. Sub on sub out. This thing cost me about §40. Do a search for Zealum. With this thing you can adjust the output voltage, it is really handy!
Found a link at amazon Germany:
http://www.amazon.de/High-Low-Konver.../dp/B000WMGK96
eliaz is offline   Reply With Quote
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
USB Sound Card GreenBeast Car Audio 4 03-21-2006 05:06 PM
Sound card : PCI vs USB help please AyrtonSennaD Car Audio 4 02-26-2006 10:01 PM
USB Sound Card Option LowLux Car Audio 5 11-23-2005 11:42 AM
Can anyone recommend a USB sound card? jedi7001 Car Audio 1 10-17-2005 09:06 PM
