Old 01-03-2008, 09:31 AM   #1
garybuk is an unknown quantity at this point
dual voice 4ohms x2??? please help!
i have two 12" dual voice coil 4ohms subs!(pyle)
i have two amps only 4ohm stable! (vibe vp2)
how would i wire my subs to work at 4ohms! please if anyone can help ill be VERY GREATFULL!
garybuk is offline   Reply With Quote
Old 01-03-2008, 12:57 PM   #2
Mylt1 is an unknown quantity at this point
are you wanting to run each sub off its own amp or both subs off one amp?
Not gonna happen with 1 sub 1 amp. you have to wire the subs together and to one amp to get a 4 ohm load. 4ohm DVC=2ohm or 8ohm load. two 4 ohm DVC=1ohm, 4ohm, or 16ohm. you want to wire them series/parallel but you will need 4x the needed wattage of each VC or double the wattage of the 2 vc's together. so if there 150w per vc you would need a 600w RMS amp. what model subs and amps?
Mylt1 is offline   Reply With Quote
Old 01-03-2008, 06:36 PM   #3
boomintrac's Avatar
boomintrac will become famous soon enoughboomintrac will become famous soon enough
If your amps are 2 channel then you can run one coil off each amp channel.
Aron
Zapco DSP-6
Zapco 500.1-Midbass-X2
Zapco 360.4-Midrange
Zapco 360.4-Tweeters
Zapco 500.1-Sub
boomintrac is offline   Reply With Quote
Old 01-03-2008, 08:27 PM   #4
the amp is the vibe vp2( i have two)
the sub is the pyle pl1290bl(also have two)
really wana get em wired up probley
Old 01-03-2008, 08:29 PM   #5
Aron
Thats a goood idea!!!!! will it work lol??? makes sence i think!!
so take a -/+ from on side to one channle and the same for the other side to one amp
then the same for the other sub to the other amp?
Old 01-04-2008, 11:49 AM   #6
boomintrac's Avatar
Yes that will work just make sure if you have 2 gain settings on each amp they are at the same level using a multimeter.
Aron
Zapco DSP-6
Zapco 500.1-Sub
Old 01-04-2008, 06:15 PM   #7
Aron
i have a multimeter but how n ware would i do that??? sorry i understand what you mean! just not quite sure how
Old 01-04-2008, 09:05 PM   #8
pokki is an unknown quantity at this point
set it to measure ac voltage and connect to the speaker outputs. make sure the voltage reading is the same/close enough for each channel.
pokki is offline   Reply With Quote
Old 01-05-2008, 07:33 AM   #9
wicked!!!!!!!!!!!!!! iv always wonderd how to do this!! nice!!! !!!!
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Can the M2-ATX handle the Energy Efficient 65W Athlon64 X2 Dual Core 4400+ CPU? Tekka Newbie 4 04-26-2007 01:09 PM
Need to know about Single and Dual Voice Coils edrex Car Audio 7 06-07-2006 09:26 PM
Dual Voice coil 12" installation.. Glockwork3 Newbie 13 05-24-2006 08:23 PM
dual voice woofer problems! luper Car Audio 13 01-26-2006 03:16 PM
