Old 01-04-2008, 04:32 PM   #1
galvitron's Avatar
galvitron is an unknown quantity at this point
Realtek ACL888 and bitperfect?
Can the Realtek ACL888 be used with a bitperfect option? I am having a hard time finding this out.
If I look at this bitperfect wiki:
http://www.mp3car.com/wiki/index.php/Bit-perfect
It lists the ACL880 and ACL 882 as being bitperfect compatible. From the numbering it seems as if the ACL888 is newer and should be compatible.
Any way to check this?
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
galvitron is offline   Reply With Quote
Old 01-06-2008, 10:01 AM   #2
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
Do you have the motherboard already? If so, I'd try all the tests that were gathered for the bit-perfect wiki article.
It appears it's capable of 44.1Khz/48Khz/96Khz on the spdif, so I could also assume why not? But you would have to test it to make sure.
System always under construction
durwood is offline   Reply With Quote
Old 01-07-2008, 01:22 PM   #3
galvitron's Avatar
I do have the motherboard. It's the Commell LS-372.
I will give it a shot if no one can confirm by the time I try...
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
