I have a Infinity 1211a mono amp here are some of the specs; 854 watts RMS x 1 at 4 ohms (1300 watts RMS x 1 at 2 ohms). I also have four (4) 12" Infinity 12.1 subs (SVC 1400 watts peak 75 - 350 watts RMS @ 4 ohms). I found this diagram to wire them up...
http://www.crutchfieldadvisor.ca/lea...SVC_4-ohm_mono...
Now the issue...in the 1211a amp there are two sets of terminals to make it easier to connect multiple subwoofers. The terminals are connected internally in parallel...if you click on the last pic should be the right view you'll see what i mean... (
http://www.crutchfield.com/App/Produ...08R1211A&g=120).
So how would i connect the subs to the amp to achieve the most power to get the most bass? or is that wiring diagram the only way...
