Old 01-05-2008, 01:16 PM   #1
dhantiflag's Avatar
dhantiflag is an unknown quantity at this point
sound wont go loud....
so i had a 2006 Civic EX and i had my carpc installed.. i used the factory amp that comes with the car 350 watts and everything worked perfect, i was able to turn it up loud as i could with stock radio...
but now i own a 2008 civic SI and i was going to install it.. but when i went to test the audio, it was so quiet and i couldnt get it louder...
these cars have the same factory amp and i wired it the same way... any ideas?
dhantiflag is offline   Reply With Quote
Old 01-05-2008, 03:45 PM   #2
pokki is an unknown quantity at this point
Sounds like you need a line driver for your PCs outputs.
pokki is offline   Reply With Quote
Old 01-05-2008, 06:11 PM   #3
dhantiflag's Avatar
? its the exact same as my old setup? only thing i can think of is... did i have the radio turned down before which actually turned the amp down?
Old 01-05-2008, 06:27 PM   #4
travisroy74 is an unknown quantity at this point
Are you saying you wired your output directly into the amp or into the headunit, then to the amp? If you are going into the head unit then it's volume would control your overall output level. If you are somehow going into the amp, it could look and seem the same but may have a different factory set input gain. Factory amps will not have adjustable input gains typically so you would have to feed it more signal via a line driver.
To troubleshoot properly start at the source and work your way through the signal flow. grab some computer speakers and power them with an extension cable, feeding them with the pc's sound output. Is the sound a normal volume? If so then try sending an ipod or walkman's output into the car's sound system, how does that sound. This way you're finding out if your are sending enough signal from the computer or if its something after that connection that is causing the problem.
travisroy74 is offline   Reply With Quote
Monsoon Sound System weldonzk2008 Newbie 1 09-24-2007 04:59 PM
amazing sound...only from rear...:( NYCdesignkid Car Audio 10 01-09-2007 01:01 PM
New Chip Provides High-End Sound DarquePervert Car Audio 8 12-06-2006 11:58 AM
Creative Labs Sound Blaster® Live!™ 24-Bit External USB 1.1 SpyderHatch Classified Archive 12 11-28-2005 05:12 PM
got sound? masch Newbie 20 11-17-2003 10:01 AM
