I once read a write up about why "they think" that 2 ohm speakers are more efficient. They went into detail about stock speakers testing out at under 4 ohms like 3.4-3.6 ohms before they are being used. Then after signal is given from the source unit, without the help of external amplifiers, to the speakers and the voice coils warm up, that the impedance is closer to 2 ohms.
But I question the fact that if the impedance drops after it is in use, wouldnt the aftermarket be exposed to that same type of drop? And with that question in mind, if you start out with a 2 ohm speaker, would it not drop impedance while it is in use to something like 1 ohm which in most applications cannot be handled by a normal headunit (factory aftermarket) without the help of an external amplifier rated to do so.
PROGRESS:
