Old 01-07-2008, 03:40 PM   #1
mk5fez is an unknown quantity at this point
Exclamation help needed with seting my sub up
ok ive got this sub
http://www.pioneer.co.uk/uk/products...1D4/index.html
and this amp
http://www.caraudiocentre.co.uk/prod...90_p-23024.htm
http://i234.photobucket.com/albums/e...9/lastscan.jpg
atm ive got it wired like this
http://www.crutchfield.com/learningc...F4%2Dohm%5F2ch
whats the rms output of my sub atm with that set up can anyone tell me?
now the amp says its 2-8ohm STEREO stable so does this mean that i CANT wire it to a 2ohm mono? like this
http://www.crutchfield.com/learningc...4%2Dohm%5Fmono
which my understanding is would give it more power/rms output
thanks for any help
Ash
mk5fez is offline   Reply With Quote
Advertisement Sponsored links
Old 01-07-2008, 04:20 PM   #2
pokki is an unknown quantity at this point
Per your current wiring, maximum continous RMS output is 250 watts.
Correct. Your amp is not designed to run at 2ohm bridged. Doing so could damage it.
PS that 4ohm mono bridged rating of 3700 watts is a typo. In theory I'd expect a max continous RMS output of 415 watts x1 (bridged). Which means some of the other ratings are bogus. I.e. I'd expect 2x 207 RMS at 2ohm, but the 4ohm spec may be right.
pokki is offline   Reply With Quote
Old 01-07-2008, 04:27 PM   #3
so i need a mono amp to run it 2ohm mono then, can anyone recommend one for me.
sigh thing is i bought 2 of these subs and that amp as a package and that amp is no where near the right power is it.
Old 01-07-2008, 04:42 PM   #4
Mylt1 is an unknown quantity at this point
that amp is no where near powerful enough to run that sub. the sub is rated at 1000w RMS and your amp a 2ohms is only 250w rms. you need an amp that is above 900w RMS mono in 2ohms to run that sub.
Mylt1 is offline   Reply With Quote
Old 01-07-2008, 04:46 PM   #5
If running two subs of that amp you could get 400 watts RMS out of it by wiring each sub to 8ohm then parallel wiring them to 4ohm to the amp bridged.
400 watts RMS is nothing to sneeze at. Especially when you consider it takes twice the power to gain 3db. However a good, high powered, 1ohm stable d class monoblock will get the most out of your two subs.
I've no idea what country you're in so won't recomend any specific brands/models. But if you can afford it - see what you local SPL/dBdrag competitors run. If their amps can stand the abuse they give them, then it should be good enough for you.
Another tip - always check the fuse sizing to verify if the power output is legit.
Fuse size x 13.8 volts x efficiencey (0.9 class d, or 0.6 class B) = output watts
This figure is a good approximation of the maximum continous RMS output the amp is capable off.
Old 01-07-2008, 05:57 PM   #6
would this be ok http://cgi.ebay.co.uk/JBL-GTO-1201-1...QQcmdZViewItem
its 1100rms and the sub is 1000rms does this mean that its gona dmg the sub?
cheers
Old 01-07-2008, 10:50 PM   #7
Yes that'll be fine for running one of your subs (though personally I'd never choose those JBL amps).
The extra 100 watts won't blow your sub if you setup your system correctly.
New Car PC info needed Tribalvision Newbie 1 01-06-2008 10:00 PM
Needed, Last few Norwegian translations needed veetid Centrafuse 1 06-13-2007 11:55 AM
WTB: HID Ballast needed RaiNt Classified Archive 5 07-25-2005 01:37 PM
Amplifier Needed? c0rrupti0n Newbie 7 03-15-2004 04:04 AM
My project for the day - advice needed ddt General MP3Car Discussion 2 12-02-2002 08:51 AM
