Old 01-14-2008, 01:52 PM   #1
DK888 is on a distinguished road
Rockford Fosgate or MTX??
I have an old school RF Power 1100a2 and MTX 81000D Mono D amplifier. Which is better to power my subwoofers?
I have (2) AudioPipe TXX-AP10W 10' subwoofers in a ported enclosure. Each speaker is rated at 1200W each, 4 ohm DVC.
MTX 81000D spec:
500 Watts RMS/CH x 1 into 4 Ohms <2% THD+N
1000 Watts RMS/CH x 1 into 2 Ohms <2% THD+N
1500 Watts Dynamic Power x 1 into 2 Ohms (14.4VDC)
RF Power 1100a2 amp:
http://www.carsound.com/review_archi...100a2chts.html
Which amp should I use and how should I wire the speakers and amplifier?
My 2000 Accord Project
DK888 is offline   Reply With Quote
Old 01-14-2008, 03:19 PM   #2
pokki is an unknown quantity at this point
I'd use the RF amp.
Wire each sub to 2ohm (voice coils in parallel) and then wire the subs in serries to the amp in bridged mode.
For the MTX with your subs, you only choices are running it at 1ohm or 4ohm. 4ohm will get you 500 rms and 1ohm introduces stability problems unless you mod the amp.
**Edit** Not sure why you're posting here since you got your answer a few days ago here:
http://www.the12volt.com/installbay/...asp~TID~101093
pokki is offline   Reply With Quote
Old 01-14-2008, 04:13 PM   #3
I was looking for more advice. People have different views and experience. Notice how you said to connect them to each channel and some people have recommended keeping the subs in 4 Ohm and bridging it to the amp.
E.g. http://www.the12volt.com/caraudio/wo...s.asp?Q=2&I=42
Old 01-15-2008, 12:36 PM   #4
Mylt1 is an unknown quantity at this point
are your subs 1200w rms or is that the max wattage?
Mylt1 is offline   Reply With Quote
Old 01-15-2008, 02:45 PM   #5
The AudioPipe 10" TXX-AP10W are 600W RMS and 1200w MAX
RF Power 1100a2 manual: Click HERE
Amp review: Click HERE
I was thinking of the following...
1. Use the 4 Ohm load diagram and connect the 2 terminals by bridging to the amp.
4 Ohm diagram (bottom)
2. Wire the speakers to 2 Ohm and connect directly into each of the 2 channels of the amp.
2 Ohm diagram (top)
Old 01-15-2008, 02:48 PM   #6
Quote: Originally Posted by pokki View Post
I'd use the RF amp.
By doing so, wouldn't that bring me down to 1 Ohm?
See here: http://www.the12volt.com/caraudio/wo...s.asp?Q=1&I=42
Old 01-15-2008, 03:02 PM   #7
No, it would give your 4ohm. For a 1ohm load you'd have to wire all in parallel.
What i said:
Is the same as this:
Excpet they decided to wire the coils in series and the subs in parallel, instead of the coils in parallel and the subs in series. Either way you get the same result: 4ohm mono load at the amp.
Old 01-15-2008, 03:16 PM   #8
Thanks a alot for your help Pokki! I can't wait to get my groove back! I was very disappointed after I blew my 10" L7's!
Hopefully I get my car back next week. It's been at the Honda dealership for 1.5 months now. Apparently they cannot diagnose the "car jerking" problem. I even removed my CarPC, due to them pointing to it as a possible cause.
Old 01-15-2008, 04:24 PM   #9
Good luck with the install - big bass is fun.
can someone make me a cool rockford fosgate skin shadow_blaster RR Skins 16 01-06-2007 04:44 AM
Rockford Fosgate amps for sale! Prices Posted 7179michan Classified Archive 4 09-02-2005 01:53 PM
FS like new Rockford Fosgate Punch Stage 2 10 inch sub w/box carchrism5 Classified Archive 2 05-21-2005 09:23 PM
(fs). Rockford fosgate new/old series audio equip faiz_23 Classified Archive 4 05-12-2005 11:42 PM
RFQ-5000 - Rockford Fosgate 5.1 Dolby Pro-Logic II Sound Processor Cartunes Classified Archive 6 04-02-2005 02:23 PM
