Old 01-17-2008, 06:01 PM   #1
jstick81 is an unknown quantity at this point
keep head unit or ditch it??
Since I am installing my carpc I can't decide if I should take out the head unit or leave it in. Not sure which will sound better. Please let me know your thoughts on this. thanks
jstick81 is offline   Reply With Quote
Old 01-17-2008, 06:09 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
I think that proper setup has more influence on sound quality than whether or not you use a headunit.
You choose.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 01-17-2008, 06:14 PM   #3
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
a carpc can sound just as good if not better than a head unit.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 01-17-2008, 06:20 PM   #4
pokki is an unknown quantity at this point
Depends how you want to control volume?
For me a volume dial is essential, so one option wass to run the carpc through the headunit for volume control.
The other options was to use a griffin powermate - which is what I ended up using, thus able to ditch the headunit.
pokki is offline   Reply With Quote
Old 01-17-2008, 09:30 PM   #5
I was thinking about using the griffin powermate and installing it like in this pic. Is the sound quality just as good?
Old 01-17-2008, 11:23 PM   #6
_
It's a volume control....
If you're concerned on THAT level (concerned with the impact of volume control) on sound quality you should look into an analogue volume control. HOWEVER, it's getting much more detailed than you may want to get into.
Jan Bennett
Old 01-17-2008, 11:47 PM   #7
The powermate doesn't effect the sound quality - that will all be dependant on your os/soundcard and how it's digitally adjusting the volume.
Old 01-18-2008, 01:51 AM   #8
fls27 is an unknown quantity at this point
Ditch the head unit. Beleive me... its not worth the trouble. I recently bought a new car and cant stand not having a Carputer in it. I can care less about the head unit.
fls27 is offline   Reply With Quote
Old 01-18-2008, 11:15 AM   #9
Dennis5587's Avatar
Dennis5587 is on a distinguished road
Do some more reading around the forum to really see the differences...
2006 Mazda 3
Behringer DCX-2496
JL500/1 JL10w6v2
Dennis5587 is offline   Reply With Quote
Old 01-18-2008, 11:39 AM   #10
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
If you have a reasonable headunit that has a way for sound from the PC to get in (aux in or after market adapter) I would keep it.
For many people the factory level sound is fine, this reduces upfront cost and allows you to hear the sound.... if you want better sound quality after hearing what you have.... make the decision then.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
head unit or no head unit... that is the question FusionFanatic General Hardware Discussion 49 08-27-2007 12:21 AM
Outputting from car audio head unit to home theater receiver mach5 General MP3Car Discussion 9 05-31-2007 12:20 PM
03Honda Accord-How Do I wire another head unit plus keep dual climate stock head unit Thormx037 Car Audio 6 05-11-2007 01:39 AM
Taking internal amp out of head unit. stonestatue Car Audio 5 01-19-2007 02:28 PM
Head Unit: Sony/Panasonic? OdoyleRules Car Audio 4 02-25-2006 07:03 AM
