Old 01-18-2008, 12:04 AM   #1
JimmyFitz's Avatar
JimmyFitz is on a distinguished road
Questions about factory Subs hookup
I am going to replace my factory head unit with aftermarket and I am not sure what is the best way to connect to the existing factory subwoofer in my car (2002 Ford Thunderbird which has similar sound system to Lincoln LS). I got a reciever and adapter from Crutchfield. The sub adapter has only one RCA plug.
Question 1: Should I hook it to the reciever preamp output left channel, right, or use a Y-adapter to connect it to both? If I connect to both, would that endanger the reciever since the two channels would then be shorted together?
Question 2: I have been told by someone with a similar car (different year) that their subs amp used a 5V enable instead of 12V and until they installed a 5V regulator, they had a really loud pop when the system first turned on. Has anyone seen the need for this kind of voltage level conversion on thier systems?
I asked both of these questions of a Crutchfield advisor but the answer to both was something like "Yes, you might need to try that."
Thanks for any input.
2005 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 01-18-2008, 04:17 PM   #2
JimmyFitz's Avatar
Anyone have any suggestions?
~Jimmy
Old 01-18-2008, 04:34 PM   #3
pokki is an unknown quantity at this point
Quote:
This forum is dedicated to CarPCs and installing them in your car.
The car audio forum is dedicated to integrating your car audio system with your CarPC.
For specific questions related to car audio equipment systems that do not include CarPCs, I would recomend checking out car audio specific forums:
http://www.elitecaraudio.com
http://www.carsound.com
http://www.caraudioforum.com
http://forum.sounddomain.com
http://www.realcaraudio.com
http://www.carstereo.com
http://www.caraudiomag.com
http://www.termpro.com
http://www.the12volt.com
http://www.talkaudio.co.uk
http://www.caraudiosecurity.com
et. al.
There is a chance that someone on here might have an answer for you, I would just hate for you to wait around for it when I know you could get an answer much quicker on a dedicated forum.
Good luck.
pokki is offline   Reply With Quote
Old 01-18-2008, 08:55 PM   #4
jontz's Avatar
jontz is an unknown quantity at this point
I have a 2000 Lincoln LS with the factory subs, and it does use a +5V turn on for the factory amp. You can feed it with 12V at your own risk, but I would highly recommed finding a way to feed it using 5V as you will eventually burn out the remote turn on section of the amp.
As for feeding signal to the amp, I would definitely use a Y adapter and use both preamp outputs. Not all bass comes from the left or the right channel, you need both.
Pokki is right in the post above though, you might look for a dedicated car audio forum for these types of questions...you just happened to luck out that I have an LS
jontz is offline   Reply With Quote
Old 01-18-2008, 11:41 PM   #5
JimmyFitz's Avatar
Smile
Thanks Jontz. I already had the Crutchfield guys opinion and I was just hoping for a confirmation like yours. I appreciate the advice.
~Jimmy
Old 01-19-2008, 12:01 PM   #6
jontz's Avatar
No problem....glad to be of service!
Old 01-20-2008, 01:39 AM   #7
JimmyFitz's Avatar
Success
I installed the new head unit today. I used a 5V regulator and Y cable as discussed. Thanks again Jontz. I replaced the Ford factory 6-disc changer that was plagued with stuck disc errors. It had no means for an aux input either so I have been using an FM transmitter for my PC output, a huge compromise. I chose a new Clarion FB275BT Digital Media reciever
http://www.crutchfield.com/S-glCTaUz...75BB&s=0&cc=01
and two pairs of Polk Audio dB5251
http://www.crutchfield.com/S-glCTaUz...5251&s=0&cc=01
Sounds awesome and supports my Bluetooth phone hands free. Progress!
My touchscreen is currently mounted on a stalk by the console. My next phase is to relocate this new head unit lower in the stack and get my touchscreen mounted in the double DIN bay.
~Jimmy
Old 01-20-2008, 06:52 PM   #8
jontz's Avatar
I believe that this aux in adapter works in your Thunderbird, it's the same one that works in my LS:
http://www.crutchfield.com/App/Produ...1DFF20&tp=1672
Moot point now since you have a new radio
Good luck on the monitor remount, and glad to hear that you are making progress!
FS: Arc Audio 5150XXK, Focal K2P seperates, 27KX subs RedGTiVR6 Classified Archive 11 12-14-2005 10:10 AM
Will someone be willing to answer a few questions about the Vietnam War for an essay? guitar333 Off Topic 6 05-25-2005 12:53 PM
Infiniti I30 2001 carputer to factory system question... smokar Car Audio 3 12-03-2004 05:51 PM
starting project soon, questions.. tekknikal General Hardware Discussion 1 05-28-2002 07:47 PM
Eclipse 5341R questions Lori General MP3Car Discussion 0 03-29-2002 01:02 PM
