Old 01-19-2008, 08:51 PM   #1
2L_SS is an unknown quantity at this point
Onboard audio help
Is it possible to go from the onboard audio of a Intel D201GLY2 mobo to 4 channel audio without a soundcard?
"Who run Barter Town?"
2L_SS is offline   Reply With Quote
Old 01-19-2008, 09:46 PM   #2
jumbodogs's Avatar
jumbodogs is an unknown quantity at this point
Looking at the link you give I don't think you can. Check out page 14 of this PDF.
jumbodogs is offline   Reply With Quote
Old 01-19-2008, 10:01 PM   #3
jontz's Avatar
jontz is an unknown quantity at this point
No, you can't get 4 channel sound out of this board.
jontz is offline   Reply With Quote
Old 01-20-2008, 12:53 AM   #4
Well looks like its a soundcard for me! Thanks for the help
Old 01-20-2008, 02:57 PM   #5
pokki is an unknown quantity at this point
You could just split the audio outputs into two pairs. But i've no idea if that will achieve your end goal.
pokki is offline   Reply With Quote
Old 01-20-2008, 05:35 PM   #6
I don't need surround sound I just want stereo. Is that considered 2 channel? Then I may be able to just split them.
Old 01-20-2008, 06:38 PM   #7
jontz's Avatar
If that is all you are looking for, then yes just split the stereo output into 4 channels. I thought that you were looking for surround sound/true 4 channel audio. Sorry!
Old 01-20-2008, 06:38 PM   #8
Yes, stero sound is just two channel.
Old 01-20-2008, 10:32 PM   #9
What about sound quality? I am not an audiophile I just want something HU quality. My car has a stock Pioneer system that sounds pretty good. Will the onboard be comparable?
Old 01-20-2008, 10:38 PM   #10
Splitting the signal shouldn't effect the sound quality.
Should be - note I presume you're aware you'll need to amplify it.
Old 01-20-2008, 10:52 PM   #11
Ya I plan on using the stock amp. Its only 270W but it gets the job done and makes my life easier.
Old 01-21-2008, 09:15 AM   #12
jumbodogs's Avatar
If he uses a Y cable doesn't that 1/2 the voltage going to each channel? Can't this effect SQ? I am not sure on this just curious. I have 2 amps 1 4 channel and another 2 channel. I was at first just using the line out on my card and splitting it to my amps but after I used separate cables for each amp (total of 3 cables ... 2 went to the 4 channel amp and 1 to the 2 channel amp) my system sounded much better. I know this isn't an option for him unless he wants to upgrade but thought I would mention so he would know what he would get from upgrading to different soundcard. That is assuming that what I stated above is correct.
My RAMPUTER
Old 01-21-2008, 03:28 PM   #13
pancit175 is on a distinguished road
Quote: Originally Posted by jumbodogs View Post
If he uses a Y cable doesn't that 1/2 the voltage going to each channel? .
Wires connected in parallel have the same voltage at each branch, but current is divided through each branch.
PROGRESS:
pancit175 is offline   Reply With Quote
Old 01-21-2008, 08:58 PM   #14
Well after talking with my buddy today I have decided to go with a 4 channel soundcard. I was a little confused with the 2 channel setup, I'm new to this car audio thing. Anybody have a good recommendation for a 4 channel pci soundcard? I'm looking $100ish price range.
Mini-ITX boards RedGTiVR6 General Hardware Discussion 112 04-29-2009 09:08 PM
Is the onboard audio on the infill t3 anygood? trunks9_us Newbie 0 04-16-2007 03:37 PM
Usb audio vs onboard digital audio nasa Car Audio 9 02-28-2007 09:02 AM
Getting Rice Krispies with MII10000 onboard audio nyeark Car Audio 21 05-24-2006 04:54 PM
standard audio for mini-ITX boards Vchat20 General Hardware Discussion 3 07-13-2005 11:50 AM
