Old 02-04-2008, 08:26 AM   #1
tjmike is an unknown quantity at this point
Question Need HELP! Headunit wont play while engine is running
Ok here is one for the experts, i have a 2006 joyner sandviper / Dune buggy 3cylinder engine full size alternator 12v system. I recently installed a JVC headunit and some speakers. The headunit plays fine and everything works perfectly...with the engine off when i start the engine the unit display just blinks, i have the constant power right to the battery, and the other 12v to a key on power, unit is grounded to frame. now i belive i figured out that not running the battery voltage is 12.25 running it is 14.40. so that trips up the head unit... question is how do i regulate the voltage to stay in the 12v range so the headunit will play with the engine running?
THANKS IN ADVANCE
tjmike is offline   Reply With Quote
Advertisement Sponsored links
Old 02-04-2008, 11:15 AM   #2
MySQL Error
scott_fx's Avatar
scott_fx is on a distinguished road
all car audio is designed to run at 14.4v. thats not your problem
New System in progress:
M10k
Phaze TD1500 ~> Seas g18rnx/p
Zapco Ref 500.1 ~ 12" tc-9
Transflective Xenarc
My Car Pc Install
scott_fx is offline   Reply With Quote
Old 02-05-2008, 07:45 AM   #3
well ok i understand they can run at 14.4 but there must be some voltage spikes coming from the alt. cause everything else is setup perfectly/ any way how can i regulate the voltage anyway?? I bought a Radio shack 7812 regualtor 1 Amp. i put it in line with the constant power, makes it light up but no play??
Old 02-05-2008, 11:34 AM   #4
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Something is not wired correctly, plain and simple.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 02-05-2008, 01:20 PM   #5
MySQL Error
scott_fx's Avatar
yeah, i have a feeling it doesn't have anything to do with the radio either. did you test all the voltages after you start the car? does the h/u stay on if you temporarily connect the ign lead on the harness to the 12v constant?
M10k
My Car Pc Install
ARGH! Engine noise!! JayKaye Car Audio 23 06-01-2008 06:08 AM
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 10:11 PM
Inverter and running engine? (Supra) Power Supplies 3 08-28-2005 07:50 AM
Any ideas on where to get a wire with +12V onlywhen engine running? RFMan Power Supplies 15 06-06-2005 10:30 PM
cant play dvd's on media engine 2.0 streetknight ME Archive 3 01-15-2004 03:51 AM
