The MP3car.com Store
Thread Tools Display Modes
Old 02-07-2008, 07:12 PM   #1
nobb's CarPC Specs
My Photos: (14)
Anyone try modelling clay to improve midbass?
My components sound great, but I am trying to squeeze a bit more midbass from them for a more rich, full sound.
On car audio forums, I see many people applying modeling clay in between and around the speaker and the door. The theory is that this isolates the speaker better and reduces the vibrations transmitted to the door. I am wondering if anyone tried this and noticed a dramatic (or atleast noticeable) improvement in midbass? Any special tips or techniques that I should be aware of? I live in a place where the weather can go from -40C to 30C, so I probably will be using rope caulk (as high density as I can find) instead of clay.
All my doors are deadened with 3 layers of Resisto and a thick layer of heavy foam in between the actual door and the interior trim piece. The door is sealed off such that the rear waves from the back of the speaker cant interfere with the front waves (in theory). It lowered alot of road noise, but to be honest the midbass improvement from this wasnt as dramatic as I had hoped. I am a bit skeptical on whether I will even notice a difference with a modelling clay mod, so Im wondering if anyone has any experience with this.
nobb is offline   Reply With Quote
Sponsored Links
Old 02-07-2008, 10:35 PM   #2
boomintrac's CarPC Specs
boomintrac's Avatar
Vehicle: A little white wagon
My Photos: (0)
My guess would be to ask Red, as I know she has used it before but I thiink it was mostly for a sub enclosure. I know someone else was interested in this about a year ago try a search and see if anything pans out. I also believe the reason it was not persued was for the weight issues that would cause door problems down the road (I.E. sagging and misalignment)
Aron
trukz
boomintrac is offline   Reply With Quote
Old 02-08-2008, 07:38 AM   #3
Car Audio Moderator
durwood's CarPC Specs
durwood's Avatar
Location: Chicagoland - Finally settled in St. Charles,IL
Vehicle: 06 MazdaSpeed6
My Photos: (0)
Depends on if your door panel is still creating cancelations.
It definitely isolates, but at a cost of a loss of output ~3db where the energy is turned into heat.
If you need more midbass there are several options:
1) Enclosure if it's a low Q driver (QTS=0.2-0.4)
2) More power (depends if the driver can handle it)
3) More excursion (depends on if the driver has more to go or if it's already maxxed out)
4) Larger driver or more cone surface area (double up on drivers)
Not sure what frequency range you are using them in either.
Proper blending with the subwoofer will help you in the illusion of upfront bass. Time alignment and/or phase adjustment and proper crossover filtering can help with this.
durwood is offline   Reply With Quote
Old 02-16-2008, 10:40 AM   #4
nobb's CarPC Specs
My Photos: (14)
Thanks for the suggestions. My components were pieced together by myself and the crossover was also self built from bare parts. The midbass driver I am using is the 5.25" Audax Aerogel (wish I went with the 6 inch instead):
http://www.partsexpress.com/pe/showd...number=296-155
It has a QTS = 0.41. The crossover I designed is a 12db/octave linkwitz-riley at 4200 hz. My 4 channel amp also separates the components from the sub at a fixed crossover at 80hz, 12db/octave. I am pretty satisfied with my components, I guess I was just hoping for a cheap and quick solution to up the midbass.
That number seems fairly significant. But whether it is a noticeable difference by the average listener, I dont know. My amp is capable of feeding each channel 75 wrms (but my components are 6ohms, not 4), and I dont listen to music at extreme levels so a little loss in output doesnt bother me.
Old 02-22-2008, 07:22 AM   #5
Vehicle: 2004 Volvo S60r
My Photos: (0)
If you've installed a bunch of damping material in the doors already, modeling clay isn't going to help.
Try this:
Disconnect the subwoofer and listen only to the front speakers. If the crossover frequency is adjustable, set it for the lowest frequency that provides crisp clean sound at the loudest level you'll listen. Don't pay much attention to the frequency markings on the amp. Then, add the subwoofer. If the crossover frequency is adjustable, set it to the same frequency as the front (now you do have to pay attention to the markings). Listen in the driver's seat and ask someone to reverse the phase of the subwoofer while you listen (or do it yourself). Choose the setting that provides the MOST midbass. Once that's done, you can be sure that the phase of the subwoofer relative to the front speakers is as good as you'll get without some additional processing.
Next, adjust the low pass frequency of the subwoofer and the gain (input sensitivity) control of the subwoofer channel until the sound is balanced.
Andy Wehmeyer
Product Marketing Manager
Harman Consumer Group
Mobile, Portable and Companion Products Division
AWehmeyer is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Clay dash bezel StealthRT Fabrication 7 08-09-2006 10:31 AM
WTB: 9" Midbass drivers (or other large midbass) morgande Classified Archive 1 04-01-2006 11:14 AM
I started using the clay today! That's right! CLAY! Mrbmw99 Fabrication 51 11-25-2004 03:09 PM
clay and fiberglassing zerosiggls Fabrication 44 07-12-2004 10:54 PM
What do you think of my playlist?? SkinnyBoy Software & Software Development 19 07-19-2001 12:51 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
