The MP3car.com Store
Thread Tools Display Modes
Old 02-20-2008, 12:53 PM   #1
My Photos: (0)
start-up pop and crackling
when i turn the key in my car and the amplifier gets power, it makes a very loud POP sound. also, when i listen very closely to the music, i can hear a slight crackling, not a steady crackling either, but sporadically. what is causing these?
krazietweak is offline   Reply With Quote
Sponsored Links
Old 03-03-2008, 08:11 AM   #2
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
this thread should not have been posted in the high end forum....why it was I don't know...
as for your system....the only real reason for turn-on thump (non-carPC related) is a cheap amplifier.
Unplug the RCAs at the amplifier then turn the system on/off a few times. If you still have the noise, then it's the amplifier. If not, plug the RCAs back in, turn the gains down, and turn the system on/off a few times, if it goes away, then you have your gains set too high.
The crackling you've been hearing could also be blown speakers...cause by a crappy amp or improper tuning (turning the gain controls all the way up unjustly so).
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Old 03-03-2008, 08:40 AM   #3
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
Do you have the amp remote hooked up to acc power or a remote turn on lead?
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
