Old 02-26-2008, 11:20 AM   #1
harminoff is an unknown quantity at this point
why do my front speakers bottom out?
Here is my current setup
deck
http://www.crutchfield.com/S-kw4l6Lj...MP2035&tp=5684
Front speakers
http://www.sonicelectronix.com/item_...stics+S35.html
Rear speakers
http://www.sonicelectronix.com/item_...stics+S85.html
Sub amp
http://www.sonicelectronix.com/item_...L+CS300.1.html
sub
http://www.sonicelectronix.com/item_...S-W1207D4.html
This system sounds awesome when I listen to rock, but when I listen to rap, my front speakers seem to clip/distort pretty bad at louder volumes. I went and got these bass blockers
http://www.crutchfield.com/App/Produ...locker&tp=3216
It helped a little, but not really all that much. Would my best bet be to get another amp for the speakers?
For instance this one?
http://www.sonicelectronix.com/item_...BL+CS60.4.html
Will this eliminate my problem?
harminoff is offline   Reply With Quote
Old 02-26-2008, 11:44 AM   #2
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
It's because you're trying to get those speakers to play frequencies that are too low for them. They aren't designed to play that low. That's why subs exist.
Without looking at that HU, I'm going to assume it doesn't have any kind of cross over function built in.
Pick up a decent amplifier with built in cross overs and set the cross over for high pass (this allows only the higher frequencies to go through). Since you're using such small speakers up front, you need to set the high pass for 250 Hz or more. If the 4 channel amplifier that you get has the ability to set 2 channels at one cross over point and the other two at another cross over point, set the rears at 120 Hz or so high pass.
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 02-26-2008, 07:07 PM   #3
BasslineMilitia's Avatar
BasslineMilitia is an unknown quantity at this point
remember you wont always get that good performance out of teh front door speakers unless you put some effort into the enclosure. Usually there isnt enough air inside the door panel to enable decent bass.
for clearer sound from yoru front crossing over your fronts will definaltly help like the guy before me mentioned
BasslineMilitia is offline   Reply With Quote
Old 02-26-2008, 07:10 PM   #4
_
3.5" speakers don't need that much air space....a bet a door is ample space for speakers of that size...and I'm no 'guy'...
Jan Bennett
Old 02-26-2008, 07:16 PM   #5
oops XD Forgive me *bows slightly
You sure about tha air space? I've had soem soundstreams preform way better after a custom enclosure on the door to provide more air :0
unless you talkign like 15W it wont make that much of a deal =\ or if you werent asking for more mid-bass
Old 02-27-2008, 02:10 AM   #6
It is actually front panel speakers and not door speakers, if that makes a difference.
It's for an 86 dodge 600.
can someone link me to a guide showing what you mean by crossover? Or how to go about setting them up in my car.
Old 02-27-2008, 03:26 AM   #7
ptk
ptk is on a distinguished road
actually your deck's specs says
Quote:
Audio features:
# System Q Sound Control (6 EQ curves and a 3-band equalizer)
# "Supreme" audio processing for better sound from your compressed MP3 and WMA files
# speaker settings that allow you to tailor the sound to the size and type of speakers in your car
# low-pass filter on preamp outputs
suggest try setting the speaker setting to "small after market speakers"
CarPC Ver 4 completed. Aopen i45GMT-HD, C2D mobile 2GHz. Photofast 64GB SSD. Novatel EU-850D
ptk is offline   Reply With Quote
Old 02-27-2008, 03:28 AM   #8
ptk
http://en.wikipedia.org/wiki/Audio_crossover
Old 02-27-2008, 10:49 AM   #9
yep I've had it on that setting sense day one.
Old 02-28-2008, 11:35 AM   #10
ok so I decided that I am going to go and get that 2nd amp. What else will I need wire wise and whatnot to get this installed?
I think i blew my speakers...not sure senseless228 Car Audio 1 01-09-2008 05:29 PM
Radio only plays from front speakers Uraijit Road Runner 3 10-31-2007 09:37 PM
4ch AMP powering 6 speakers? Alfredbra Car Audio 5 10-30-2007 06:44 PM
Why not PC speakers? checksum Car Audio 372 10-04-2007 09:02 AM
Only works front speakers JosepZ MediaCar 4 01-16-2005 05:52 AM
