03-04-2008, 01:07 PM
#16
Raw Wave
Vehicle: 07 Jetta
I was not happy with SB live, and now not even 2 NX... I just dont understand why it sound so much better when going from board sound to the aux of the cd player and then to the amps?
07 Jetta
Carputer:
Voompc-2, Intel 1.33, 1GBram, 60gb HD, Dynamix 8"
Audio:
front Qsd 216
Rear QSD 213
Rockford (2) p2 10" subs
JL 500/1
JL 300/4
Audigy 2 nx
03-04-2008, 02:38 PM
#17
Vehicle: 2005 Toyota Celica GTS 6
Hmm .. I'm using on-board sound to my Sherwood DTS, then to my PG Octane 5 channel amp. I just got it working Sunday and it snowed here yesterday so I havn't had a dry day to work on the car. Once I finish getting the rest setup, I'll see if I can get the same problem as you.
03-05-2008, 09:31 PM
#18
im using an NX now. works okay, but im looking for something else that can output dual stereo.. or worse comes to worst a stereo only DAC.
The CMSS settings for dual stereo doesnt stick after reboot.... so its kinda lame. and if you turn off cmss, you lose your rear channels. This sound card COULD be really good, if it had better software... its just too bad none of the 3rd party drivers work on it, otherwise i would consider keeping it.
Carputer HIFI car stereo project!
[XXXXXXXXXXXXXXXXXXXXX-]
95% COMPLETE! FINALIZING SOFTWARE PLATFORM!
[XXXXXX--------------]
30% COMPLETE! CAPUTER Version 2.0! Hardware FAILING! CARPUTER BLEW UP! AND NOW MONITOR TOO! WTF?!
03-05-2008, 09:39 PM
#19
Dual Stereo? Do you mean Quadraphonic?
03-05-2008, 11:01 PM
#20
no, dual stereo.. its under the CMSS settings. Basically its the same signal as the front speakers, but using the rear outputs. basically its what you would want to emulate a regular ol stereo without having to use any splitters, etc.
03-06-2008, 03:37 AM
#21
Vehicle: 1999 Regal LS
Is that card supported by the Kx drivers? If so, they are definitely the way to go. They allow you to do basically anything you could ever imagine with the DSP. Sounds amazing with my Live 5.1 and I've only just BEGAN to understand how to set up a proper DSP and going active via the drivers.
CarPC:
1.8GHz Northwood, Intel 845 Mobo, 512MB DDR, 1x20GB + 1x160GB, Intel GPU, SB Live 5.1
Sound System:
Phoenix Gold RSD 65cs 6.5" Comps, 2 x 12" Pioneer 305DVC, Visonik V500HC
03-06-2008, 03:39 AM
#22
unfortunately no.. i wish it was. kxproject doesnt support the USB versions as its a completely different chipset...
if only there was someone who could build a working driverset... that would be awesome.
03-25-2008, 12:37 AM
#23
Vehicle: Subaru 2003 B4
So peeps, should I invest in a Sound Blaster Audigy 2 NX?
What I want is front and rear with a 12inch sub.
Source would be coming from line out of motherboard and then feeding into the NX.
Now I know the boys over @ XTroniC were working on a USB digital AMP, any word on that?
Parts list - in AUD$
Lilliput 629 $270 | Hitachi 5400RPM 80G $92 | PIO DVR-K05 slot $95 | AYAY SIR Quad port GPS $160 | DSATX 220W PSU $205 | Mechatroniks Bezel $186 | Kino-9453 MB $380 | A-Data DDR2 667 2Gig $140 | 2 X CCD Cameras $180 | HQCT -e $140 |
03-25-2008, 02:23 AM
#24
why would you feed the line out from the motherboard to the NX? the NX is a soundcard by itself, so you would just hook the NX directly to your amps.
03-25-2008, 07:34 AM
#25
cheap custom title
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
The amp is nearly finished, pictures will be available later today... It's a stereo DAC + amplifier with analog fader adjustment and line out for a sub amp.
Keep an eye on our site...
Joachim
03-26-2008, 12:24 AM
#26
Forgot it was USB driven, DOH!
So either I invest in one of these or wait for XTroniC to drop there price on the amp
03-26-2008, 08:08 AM
#27
Vehicle: 06 Acura TL
I use an NX, and I find the card great for providing an optical connection to my processor (Alpine 701). There are a few caveats, tho:
1. CMSS and all effects must be off...I have yet to find the processed effect that I like
2. Volume must be at 100%...it doesn't make any sense from a sound quality standpoint to do software volume control when you're outputting over S/PDIF...any digital attenuation done of the original signal when you're outputting in the same fixed digital format can be seen as a loss of resolution. I don't know what the card is doing re-sampling-wise, but there is a definite loss of clarity when the volume is messed with.
Which brings me to another annoyance...I don't know what the issue is, but sometimes I find that my volume in Windows changes without me changing it. There has been many an occaision where I've found myself going nuts trying to figure out what went wrong with my sound, then found that my volume in Windows was at 75%.
03-26-2008, 05:37 PM
#28
heh.. im actually thinking of selling my nx and picking up a behringer dac.. or perhaps two of them?
anyhow.. usually output over SPDIF is a line out with no variable volume. so usually your processor should take care of any volume changes.
the CMSS setting you may want is the "Dual stereo" option. F+R output the same signal. Im not familiar with the alpine, but im assuming it takes a 4 channel setup.
I have issues with mine when it gets too hot.. the sound card likes to mute itself on and off. :P
03-29-2008, 01:18 PM
#29
Vehicle: 2000 Protege
Did you upgrade and flash the firmware? There was some upgrades to the drivers as well since the original distro of the software that is on the CD.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
03-30-2008, 12:06 AM
#30
yes, i have upgraded the drivers and everything, as there were similar problems initially as well.
| Thread Tools |
| Display Modes |
Linear Mode
