The MP3car.com Store
Thread Tools Display Modes
Old 02-28-2008, 06:02 PM   #1
Raw Wave
kickercivic1's Avatar
Vehicle: 07 Jetta
My Photos: (0)
Audigy 2 NX
Anybody think the software for this card sux??? my sound with this card is all messed up...
07 Jetta
Carputer:
Voompc-2, Intel 1.33, 1GBram, 60gb HD, Dynamix 8"
Audio:
front Qsd 216
Rear QSD 213
Rockford (2) p2 10" subs
JL 500/1
JL 300/4
Audigy 2 nx
kickercivic1 is offline   Reply With Quote
Sponsored Links
Old 02-28-2008, 07:29 PM   #2
Nola111's CarPC Specs
Nola111's Avatar
Vehicle: 2006 VW Passat 2.0t
My Photos: (1)
For the year or so I used the Audigy 2NX as my sound card, I didn't use the included software, and I actually thought the sound quality was quite good. It depends a lot what you're running it into as well though.
Nola111 is offline   Reply With Quote
Old 02-29-2008, 08:53 AM   #3
Ineffigy's CarPC Specs
Vehicle: 2005 Toyota Celica GTS 6
My Photos: (0)
Yeah, I've seen the Audigy 2 NX in action. It works pretty damned good. maybe you have somthing that conflicts with it?
Ineffigy is offline   Reply With Quote
Old 02-29-2008, 09:20 AM   #4
Raw Wave
Vehicle: 07 Jetta
My Photos: (0)
My 2nx works great, but the my Tweets are crazy loud and i hardly heard the singing part of it... The EQ in the sound card is just BS... Just to get bass you have to turn on CCMS or whatever and then click on surround sound... well that makes that music echo... I have very powerfully system, so i hear it and i hate it.. When i had audio running thru the deck it was perfect..
07 Jetta
Carputer:
Audio:
front Qsd 216
Rear QSD 213
JL 500/1
JL 300/4
Audigy 2 nx
Old 02-29-2008, 01:44 PM   #5
My Photos: (0)
Are you set up for stereo or quadraphonic or what? Are you connecting your RCAs directly to the 4 channel AMP? Or do you have a graphEQ in between? What's your setup like?
Old 02-29-2008, 02:06 PM   #6
Nola111's Avatar
My Photos: (1)
What version driver are you using?
Old 02-29-2008, 02:22 PM   #7
Raw Wave
Vehicle: 07 Jetta
My Photos: (0)
How do you find that out?? Are you set up for stereo or quadraphonic or what??
Here is my setup.. from the sound the front and rear is running into 4 channel amp and sub to sub amp.. No graphEq or anything.....
07 Jetta
Carputer:
Audio:
front Qsd 216
Rear QSD 213
JL 500/1
JL 300/4
Audigy 2 nx
Old 02-29-2008, 02:23 PM   #8
Raw Wave
Vehicle: 07 Jetta
My Photos: (0)
The newest one, i just download from the site.
07 Jetta
Carputer:
Audio:
front Qsd 216
Rear QSD 213
JL 500/1
JL 300/4
Audigy 2 nx
Old 03-02-2008, 03:06 AM   #9
My Photos: (0)
Ok, and are you set up for 5.1 then? Or are you setup for Surround Sound, Quadraphonic, or Stereo?
These will have huge impacts on how the sound is sent to each channel.
Old 03-02-2008, 08:36 AM   #10
Raw Wave
Vehicle: 07 Jetta
My Photos: (0)
I am setup for 5.1.... i tired all the option and sound is not good enough for me.
07 Jetta
Carputer:
Audio:
front Qsd 216
Rear QSD 213
JL 500/1
JL 300/4
Audigy 2 nx
Sponsored Links
Old 03-02-2008, 11:42 AM   #11
My Photos: (0)
In that case, you could do what RedGTIV6 did in her car, you could get a DSP with a optical connection to it. Have that send your signal out to your amps. It's the same car that won SQ competitions.
Old 03-02-2008, 11:43 AM   #12
My Photos: (0)
Also, you are missing out on the center channel. That may be why your sound is off as well.
Old 03-02-2008, 11:55 AM   #13
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
afaik, the friver only lets you choose between 4ch or 5.1 - you need 4.1 as you don't have a center speaker.
An alternative: set it to 4ch and use the line output of your 4ch amp to feed the sub amp. Use the sub amp's low pass filter.
OR
Search, try and try again, there has to be a solution...maybe using virtual audio cable (software)?
Good luck!
Joachim
JC-S60 is offline   Reply With Quote
Old 03-02-2008, 01:26 PM   #14
Raw Wave
Vehicle: 07 Jetta
My Photos: (0)
OR
Good luck!
Joachim
If i were to do that then it will avoid the purpose to the external sound card.. going to 4 channel to sub amp. Also i will have no control over sub amp...
07 Jetta
Carputer:
Audio:
front Qsd 216
Rear QSD 213
JL 500/1
JL 300/4
Audigy 2 nx
Old 03-02-2008, 03:02 PM   #15
My Photos: (0)
I use a Sherwood X-DTS80 from my sound card to my PG Octane 5.1 Amp. Though I am turning on the amp today. Wish me luck in getting the sound correct.
Sponsored Links
vB code is On
Trackbacks are Off
m10000 on-board -> audigy 2 nx -> m10000 on-board fatman Car Audio 7 02-21-2008 11:49 AM
Audigy 2 NX and hibernation backspace Car Audio 2 04-28-2006 01:56 PM
USB Audigy 2 NX, D-Link USB Hub, and 15 W POL Caelric Power Supplies 4 01-17-2006 12:02 PM
Audigy 2 NX software/cd? Urinemachine Car Audio 1 06-14-2005 06:49 AM
Audigy 2 NX and subwoofer, whats the deal? jedi7001 General Hardware Discussion 26 05-15-2005 01:17 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
