Lower resistance (ohms) means that for a particular voltage (i.e. volume knob setting) they'll use more power and be louder. However, you're not going to get 300 Watts out of a 200 Watt amplifier, so your maximum power output (actual volume) is limited by the amplifier power rating, regardless of the speaker. There are some subtleties regarding how efficient the amp is with various speakers but I believe that's more-or-less the story.
400 Watts from a 2 ohm speaker requires about 14 amps of current, but through a 4 ohm speaker requires just 10 amps. (Power = Current^2 x Resistance) Less current means happier transistors in the amplifier, and lower losses from wiring and connections.
Are you looking at bare 2 ohm speakers, or full commercial setups that are rated at 2 ohms? If they're bare speakers, I'm wondering if they're really just intended to be used in pairs (in series) to make a 4 ohm load that the amp is made for.
Slightly related -- Infinity seems to have switched from 4 ohm speakers to 2 ohm and I can't figure out why. Seems like a bad move for quality. All I can figure is that the 2 ohm speakers will sound louder when you compare them to 4 ohm speakers in an in-store display. That's a joke, of course, because they can't actually
get louder than 4 ohm speakers, it's just that at the same volume knob setting they'll sound louder. Pretty sad if they only changed them so they'd sound better in comparison displays. I'd love for someone to correct me, because I like Infinity otherwise.
All that being said, kickercivic1 is right... just get what the amp is rated for.
